Adam_Hosp
July 1, 2024
Figma Slides - Add button(s) to jump between slides?
  • July 1, 2024
  • 19 replies
  • 3779 views
I know Slides has been around for about 5 minutes, but I can’t figure this out. Is it possible to add button interactivity to Figma Slides - like having a ‘overview’ slide with links to individual slides later in the presentation? Right now, it seems to only support linear progression.
Basically, I’m looking for way to add a “jump to this section” button that skips around the presentation.
Silas_Tsui1
July 1, 2024
Hello, you can have nodes in your slide deck link to other slides by using the Link panel on the right!
Adam_Hosp
Adam_HospAuthor
July 1, 2024
@Silas_Tsui1 I feel pretty dumb asking this, but I don’t see a ‘Link’ panel anywhere. Any chance I can get a screenshot? Thanks!
Silas_Tsui1
July 1, 2024
yup, does this help?
Morgan6
July 2, 2024
I was looking for this too but I don’t have the option in the screenshot above 😭
I also would expect it to be in the animation tab, rather than design. So you can choose the transition style.
Silas_Tsui1
July 2, 2024
could you share a screenshot? which node do you have selected?
that’s a great point about setting transitions for links – i’ll share this feedback with our team, thanks!
Morgan6
July 8, 2024
Sorry, just saw this reply - I just checked back again and the option is there now. So either I had a blind moment or a bug was fixed 😅 Regardless, thank you for your help!
DeCarolis_Anthony
September 4, 2024
Will this only work with text elements? We have some buttons that help users navigate back to the title slide from any other slide but it doesn’t seem to show the “Link” panel…
DeCarolis_Anthony
September 6, 2024
Just following up on this, I feel like allowing both non-text elements and grouped text elements to act as nodes would be super helpful for more complex or lengthy presentations.
aaronjellis
I totally agree. I think most designers will want to make custom buttons and whatnot to go to a desired slide. This is much more natural for a self-guided presentation. Basically what people are doing with prototypes today instead of slides.
Quintus
September 24, 2024
Does any of you know if and how i could connect different slide decks with each other by using nodes in the same way as described above?
