Figma Motion - Overwriting Animation - Branching - Workflow
Hi there!
We have been testing Figma Motion to run a big campaign, for a lack a better workflow, we decided that a Motion branch would work as an experiment as we had numerous people collaborating. It was not ideal, but a good way for testing. We encounter a few recurrent challenges:
- When updating the branch, any animation would be overwritten by the updated component and that is inconvenient. I wish that would be a setting where I can keep the animations, specially when the update is jus a body copy text.
- The workflow/pipeline we followed is the following: set up the components with variants that will be used, create a Motion Template Component, and run a bespoke plugin that allowed us to select the different variant and create different instances of the template. For the motion Template we also created different animation styles easy to use and dedicated for each layer. I wonder if this is the best workflow possible in Figma. I feel this can be improved.
- Another recurrent challenge, was to see how some animations were overwritten often. And made it difficult to understand how the animation in the Components would influence the instance. Often, we needed to ask the Agent to fix that, spending credit on fixing this. Does Figma has a documentation that can explain how this workflow works. I can see the potential of using this for large scale campaigns, but as Motion Designer coming straight from After Effects, I struggle to understand the in and out of Figma Motion.
I would appreciate of someone could bring some light to this matters. Looking forward to hearing from you!
B.
