Tarek itani
Figma Make not using actual components
While trying to use Figma Make, and importing our components, Figma Make doesn't seem to use the actual component but rather imagines a similar one and thus losing all of the properties associated with the component. Is there a way to force Figma Make to use the actual components with their properties? Even if I specify that I want it to use the component, it doesn't.
Hi ​@Tarek itani, thanks for reaching out!
This definitely sounds frustrating. May I ask how are you providing Figma Make with your components?
While there currently isn’t a way to use an entire library, you can use predefined components from design systems you have access to as well as work with templates that follow design system guidelines.
There are two ways to attach Figma designs to a prompt:
  1. Search for a design
    • In the prompt box, click  Attach design and search for the design, component, or Community file that you want to attach.
  2. Paste a design
    • Copy and paste designs from your Figma Design files into the prompt box.
Check out our Help Center for more information on how to do this: Attach designs and images to a prompt
nikita.pashinsky.piano
Same issue here
Zoe_Bartley
using both the designs link and uploading a library- make still does not match a lot of the design
In a simple flow, it misses full pages and content
John Klopping
Same. I uploaded my frames, used chat GPT to prompt it, outlining every element and how to make sure it matches, and it just hallucinated it’s own, entirely separate site.
