Nicole_Emenhiser
Apr 9, 2025 7:02 PM UTC
Figma library updates always one step behind?
Hey folks, I’m running into an issue and curious if anyone else has had the same issue. I’ll put it in a list just to keep things orderly:
  1. First, I make a change to my library, then publish the change
  2. Then I check the document it’s linked to, and check for an update. I see an update, but it’s actually a previous change that also didn’t go through.
  3. If I go back to the library and make one other change and publish, then return to the linked document, now I can see the previous change.
This isn’t the worst thing, I can just be-bop things around and fake a second change to get the first to go through, but it is a little silly 😅
Has anyone run into this? Would you happen to have a solution?
