Ravi Ranjan
Oct 22, 2026 5:06 AM UTC
Figma Library Adding Issue
First I created a new Figma design file A in the team XYZ then, I was able to see my organization library PQR, I added , then with some reason I removed , but again when I want to add it again , but the same library not appearing at all. But in the same team XYZ, I created another design file B, again I am able to see the same library PQR, what could be the reason.
Jaycee Lewis
Oct 22, 2026 6:29 PM UTC
Hi ​@Ravi Ranjan 👋 Welcome to the community! To confirm:
  • You're able to find and enable the organization library in a new design file
  • After removing it from your original file, the library no longer appears as an option to add again
  • Is that correct?
Could you share a few more details to help us investigate?
  • Screen recording: Could you share a recording showing how you're removing the library from file A, what happens when you try to add it again, and how the same library appears in file B?
  • Where you're looking: Are you searching for the library under Assets → Libraries, or somewhere else?
  • Troubleshooting: Does the library remain missing after refreshing file A?
Thank you! — Jaycee
