Please search for existing topics before posting! Press 🔍 at the upper right to search
I am having problem opening Figma file Figma desktop app. It stays on loading mode for indefinite time.
I tried restarting my desktop. I am using windows.
Is there any suggestions?
Hello, did you solve your problem? I’ve been having the same problem for a few days now. The documents don’t open and just keep loading.
I am having the same issue for the past 3 months with Figma Mac desktop/Web. I have to restart Figma multiple times and it is frustrating as our IT team can’t resolve the fix.
Is there any solutions for this?
Hey everyone,
Sorry to hear this is happening! As a first workaround, can you try closing all the Figma file tabs, clearing your browser or desktop applications cache to see if this helps improve anything. Then, force-quit in your browser and/or desktop app?
You can clear the desktop app cache on Windows under the toggle-arrow at the right of the top toolbar under Help > Troubleshooting. If you’d prefer to manually clear your cache you can:
  1. Close the Figma desktop app
  2. Open the Start menu, and paste in this, followed by enter: %APPDATA%\Figma
  3. In the window that opens, delete the Desktop and DesktopProfile folders if they exist
  4. Launch the desktop app again
On Mac, use the Terminal app to clear the cache.
  1. Quit the Figma desktop app.
  2. Open the Terminal.app and enter the following command: rm -rf "$HOME/Library/Application Support/Figma/"{Desktop,DesktopProfile}
  3. Try opening the Figma desktop app again.
If this has not helped can you please try disconnecting from any VPN in use and check if these load?
Here are some additional tips to troubleshoot if this may help: My files are not opening
Hope this helps a bit!
Hello Celine,
Problem solved! many thanks!
Glad it’s working now! Thanks for letting me know 🙂
