serhii_muso
Sep 12, 2025 4:44 PM UTC
Figma code connect unpublish not working
I was testing figma code connect with mcp and Cursor and unfortunately found that i cannot refine component that is already connected - because “suggested code” is not returns, it only contains my connected info
I tried to run ‘figma connect unpubish --node’, command returns :
Unpublishing Code Connect files from Figma...
Successfully deleted:
--- (React)
--- (storybook)
* my code is vue
But then mcp again returns my code connect snippet instead of real “react code” as it was before connection
serhii_muso
Sep 15, 2025 3:49 PM UTC
Literally now we are trapped as those components cannot be received from figma dev mcp anymore.
Issue is huge
Tomas Doherty
Oct 2, 2025 3:43 PM UTC
Have you tried on the latest version? We had a similar issue with SwiftUI, and we used the argument --label=SwiftUI and it worked for us.
Andrew McCullough
Oct 6, 2025 1:24 PM UTC
I am also seeing the same issue when running `figma connect unpublish` to unpublish all components, and I still have at least one that wont disconnect / unpublish
guzman_iglesias_c
Oct 6, 2025 2:19 PM UTC
I have this issue too
Tom Reem
Oct 6, 2025 3:50 PM UTC
Hello ​@serhii_muso and everyone following along — thanks for flagging this. I checked in on this, and our engineering team was able to identify an issue that caused the behavior you’re describing here. A fix was released in the latest version of Code Connect, so updating should help get things working again:
  • If you run npm install @figma/code-connect@latest you should get the update.
  • Running npx figma unpublish --node {URL} now requires a --label flag. In this case, you can pass --label "Vue" to explicitly unpublish it.
If you’re still running into trouble after updating, it’d help to take a closer look at your file. You can share details with our Technical Quality team by filling out this form and including:
  1. a link to the file where this is happening
  2. “Can edit” access for support-share@figma.com
  3. a short screen recording, if possible.
Appreciate everyone’s patience while this was sorted — hope this helps get you unblocked!
