OG_Can
Mar 13, 2025 2:09 PM UTC
Figma AI questions
Hello,
One of my professional accounts finally has Figma AI access again, and after some usage, I have a few questions about its capabilities, and would appreciate some guidance, as I do not believe I was able to achieve the following:
  1. Can I make the AI use components from my design systems rather than its pre-defined set?
  2. Can I add components to its pre-defined component library? If yes, how?
  3. Can I make it create component sets and states?
  4. Can the AI use framework components like Bootstrap 5 if asked?
  5. Can the AI create variable tables for me for my design system?
  6. Can the AI create styles other than its initial style control interface? Like, actual text and color styles (if variables are not a go, since that is better)?
  7. Can it work on elements on a page, like a vector illustration, and modify the element?
  8. Can it create tables?
  9. Can it create flow charts/connections between frames since it can noodle?
Mar 14, 2025 2:03 AM UTC
Hi there,
It can be a bit challenging to achieve this with the current Figma AI. Here’s a list of the available features:
https://help.figma.com/hc/en-us/articles/4406787442711-What-Figma-features-are-in-beta#h_01J071T8RKD9E5P2RGC632F4V2
I hope this helps!
Toku
