tamzid
Dec 9, 2025 8:55 PM UTC
Extending line without losing the angle
How do I extend a line without losing  its angle?
    Nellya
    NellyaSolution
    Power Member
    Dec 10, 2025 11:59 AM UTC
    Thanks ​@Nellya for your suggestion! This works only if the angle is set to 45 degrees. Otherwise it will not work.
    It also works at different angles for me
    Nellya
    Power Member
    Dec 10, 2025 11:43 AM UTC
    You can extend the line by changing the number in the width input
    tamzid
    tamzidAuthor
    Dec 10, 2025 11:55 AM UTC
    Nellya
    NellyaSolution
    Power Member
    tamzid
    tamzidAuthor
    Dec 10, 2025 12:01 PM UTC
    Oh yes! Just noticed that. I think I have found the solution. Thanks a lot! You are AWESOME! 🙂
    GrevaGen
    Dec 13, 2025 6:06 AM UTC
    This is a super common problem!
    Here's the trick- Double-click the line to enter Edit Mode, then click and drag the end point while holding down the Shift key. The Shift key constrains the movement, so you can extend the line perfectly along its current angle.
