Destin_Briant
Sep 26, 2022 3:06 PM UTC
Exporting Without Folder Creation
Is there a way in export settings to not create a destination folder when exporting frames or images? Please help!
Luan_NunesSolution
Jun 11, 2024 5:44 PM UTC
It happened here to me too. And it really happens because of the “/” character used to name the frame. Just rename it by removing the “/” that exports without the folder.
Kelly_N
Sep 26, 2022 3:29 PM UTC
If you export more than 2 layers, Figma will always put them into a folder. If you export layers one by one, then Figma will not create any folders.
Mar 14, 2023 1:51 PM UTC
A colleague has the same issue. I only have the issue with her files. When I export multiple frames at once, it just exports to where ever i told it to export to. If anyone knows how to disable the export into a NEW folder, I’d be so glad because it really annoys me
Jul 28, 2023 7:28 AM UTC
I just had the same happening to me, and I discovered that if I removed the “/” my colleague used in the frame name, the problem would go away.
Dec 6, 2023 6:23 PM UTC
This worked! What a dumb bug lol.
Paul65
Dec 15, 2023 11:47 AM UTC
I found a work around when working with batch exports (i.e. icon sets).
Select all which need an export and run the https://www.figma.com/community/plugin/1183975085577339184 plugin
It will make a zip which opens without nesting.
Hope it is helpful!
Luan_NunesSolution
Samojeyinka
Feb 20, 2025 11:34 PM UTC
Just click on the image, icon or whatever is it you want to export, the mouse click on its container in the sidebar, you should see an option to group selection, after that, you would be able to export directly without it being in a folder.
Kitayoshi Son
Mar 20, 2025 9:00 AM UTC
Thanks everyone. In addition, the "/" character in the page name will also cause the export within a folder.
