natalie_bunkar
Sep 11, 2024 7:47 AM UTC
exported the pdf but the other pages are not in pdf
ive created few pages in Figma only the last pge with a4 and 1 rectangle frame is exported except all are not exported at all
Alok
Sep 11, 2024 9:01 AM UTC
If only the last page is being exported in Figma and other pages are not, there are a few possible reasons. Here’s how you can troubleshoot and export all your pages:
Steps to Ensure All Pages Are Exported:
  1. Check Frame Selection:
  • Ensure that all the pages or frames you want to export are selected. If you’re exporting specific frames or groups, Figma will only export those selections.
  • Solution: Manually select all frames or objects on the other pages that you want to export.
  1. Ensure Frames Are Properly Named:
  • Figma exports frames. If you have added objects to the canvas but they are not inside a frame, Figma may not recognize them for export.
  • Solution: Wrap all your designs in frames on each page and name the frames. Figma will then allow you to export them.
  1. Check Export Settings:
  • Go to the Export section (bottom-right when you select any frame or object).
  • Solution: Select all the frames or pages you want to export, and add export settings for each one.
    • Select the frame, click the + next to “Export” in the right-hand panel, and choose the export format (PNG, JPG, PDF, etc.).
  1. Export Multiple Frames at Once:
  • You can export multiple frames or pages by selecting them all before export.
  • Solution: Hold Shift and click on each frame or page you want to export, then go to File > Export > Export Frames to PDF or another desired format.
  1. Verify Export Type (PDF/PNG):
  • If exporting to PDF, Figma will export only selected frames or the currently visible page.
  • If exporting to PNG or JPG, ensure the right frames are selected for export.
  • Solution: Select all relevant frames and pages when exporting, especially for PDF exports.
  1. Layer Visibility:
  • Check that the frames or layers on the pages you’re trying to export are visible.
  • Solution: Ensure none of the layers are hidden (eye icon next to layers in the left panel).
  1. Page Selection in Multi-Page Documents:
  • Figma can only export selected pages or frames. If you’re working in a multi-page document, ensure you’re selecting content from the correct pages.
  • Solution: Make sure you are selecting the correct frames from all pages, not just the last one.
Export All Pages at Once (For PDF):
  • For PDF: If you want to export all pages as a single PDF, select all frames across different pages and go to File > Export frames to PDF. This will include all selected pages/frames.
By following these steps, you should be able to export all your pages and frames, not just the last one. Let me know if this helps or if you encounter any other issues!
