Will_Nandi
May 5, 2021 10:48 PM UTC
Export losing quality even using PNG and 2X higher
I am trying to use Figma as my main software to produce my designs.
But my frames are being exported with a bad resolution from Figma.
Exporting as PNG and even using 2X is not getting the full resolution as I see on Figma.
Anyone with the same issue?
SAHANA_SOOD
Jan 17, 2024 11:53 AM UTC
i recently started using Figma.
and for my first project of ui/ux i have made a case study and ui presentations.
but when i tried exporting them as pngs (even in 4x), the mockups in my project are losing quality and are blur.
how do i fix that?
SAHANA_SOOD
Jan 17, 2024 12:42 PM UTC
@gleb i recently started using Figma.
how do i fix that?
Power Member
Jan 17, 2024 2:39 PM UTC
Your mockups are probably low resolution raster images (maybe not low resolution but not high enough to export such an enormous 4x size file).
SAHANA_SOOD
Jan 17, 2024 4:57 PM UTC
i made my mockups using a Figma plugin - artboard.
can you suggest a better way to make mockups for mobile screen?
maybe another plugin or another way. or recommend any youtube tutorial that i can go through for the same.
thanks
Fawad_s_Graphic
Mar 20, 2024 12:21 AM UTC
Hey Gleb, it seems like you’re feeling a bit frustrated. However, I would still like to ask for your help with a problem I’m having. In Photoshop, when I zoom in, I can see the image in the best quality even at a zoom level of 400%. However, in Figma, this doesn’t seem to be the case. I’m wondering why this is so. 😶
Power Member
Mar 20, 2024 4:04 AM UTC
It all comes down to the number of pixels you have. Usually images you are working with in Photoshop are much higher resolution. Are you comparing the exact same image in both apps? Do you have an example you can share? Also do you have pixel preview disabled in Figma? It rasterizes everything on canvas at 1x or 2x resolution so you can’t zoom in without seeing the pixels.
Yente_van_der_Aart
Apr 29, 2024 1:07 PM UTC
This worked for me! thanks 🙂
Shravani_Maral
Apr 30, 2024 6:35 AM UTC
I Exported this icons which are almost same in size except presentation spelling space. When I exported that all Icons, the presentation icon is getting so smaller but in Figma file it is biggest icon, how to figure out this ?
Shravani_Maral
Output icons are like this…
Power Member
Apr 30, 2024 10:34 AM UTC
What do you mean?
The icons in both images look the same.
