Yong Jie
Oct 11, 2025 4:08 PM UTC
Export Figma Make files to Vue.js
Knowing that currently figma make using React framework to build the applications, is there anyway export it to vue.js ?
Gayani_S
Oct 27, 2025 12:31 PM UTC
Hey ​@Yong Jie, thank you for reaching out!
I checked in with our team about this, and here’s what they shared:
You could use Figma's MCP Server to bring the code of a Make into an existing vue.js codebase (docs). However, at the moment, there's no way to export/convert a Make into other frontend frameworks like vue.js.
Hope this helps!
Agostina Gonzalez Bano
Nov 30, 2025 7:21 PM UTC
Hi ​@Yong Jie and ​@Gayani_S! In my team we need the same since we are working with Vue. I will suscribe to this chat in case we have some updates soon. Have a nice day!
Carlos Arevalo
Dec 1, 2025 12:56 AM UTC
​@Yong Jie ​@Agostina Gonzalez Bano wondering if y’all have tried exporting the code from Make and then converting it to Vue with your LLM coding agent of choice. e.g. Claude/Claude Code or Cursor?
There’s a nice download button on the top right of the Make interface, you get a .zip file that you can then open up in Cursor/Claude Code/etc. and prompt it to convert it.
Make Code View w/ Option to Download
Idk what your team’s Vue setup is like but it could prompt the LLM something like this:
  1. Convert to Vue 3 with <script setup
  2. Convert to Vue 3 Options API
Note that you won’t be able to import back your Vue code to Make so you can keep it for prototyping if you want but your team will now move forward with the Vue code outside of Make.
👻 @sol_ar figma-forum % design && build --with-ai
Carlos Arevalo
Dec 1, 2025 1:02 AM UTC
Hope this helps!
When it comes to existing codebases, another approach might be the GitHub Connector/MCP. It allows you to push to GitHub: https://help.figma.com/hc/en-us/articles/35463818346647-Push-from-Figma-Make-to-GitHub
So maybe, but the conversion from React to Vue would still need to be done, be it manually or using a coding agent.
marenamm
Jan 14, 2026 5:53 PM UTC
also would be really beneficial to my team as we’re also building with Vue, hoping for updates on this should there be any!
Grile.Ro
Feb 1, 2026 4:08 PM UTC
Same here, would be quite nice to have figma make export to vue directly
Especially because shadcn ui is also ported to vue :)
Maximilian Georg
Mar 9, 2026 11:07 AM UTC
+1
Francis Perron
Mar 17, 2026 2:14 PM UTC
+1
Walkeven
Apr 2, 2026 12:16 PM UTC
+1000
Yang Yuxin
Apr 3, 2026 12:57 AM UTC
+1
