Sister_Audrey_Frances_Moran
Sep 21, 2023 2:55 PM UTC
Everything is underlined in red when I type in Spanish
If there is already a way to either turn off spellcheck, or to tell a FigJam file that I am working in a different language, or if that could be introduced, that would be great. I’m a new user and a Spanish teacher, and I am loving starting to use FigJam in my classroom, but it’s a bummer that most words are underlined in red!
djvSolution
Sep 21, 2023 5:51 PM UTC
Hey there, so sorry for the frustration!
You can enable or disable spell check from the Main Menu:
  1. Click on the Figma icon in the upper left-hand corner
  2. Go to Text > Spell check
  3. Click Check spelling to enable or disable spell check
You can also change your preferred spell check language from the Main Menu:
  3. Select from the list of available languages
Stella2
Sep 17, 2024 11:56 PM UTC
Hi! I’m using FigJam within my browser - Google Chrome Version 128.0.6613.138 - on a Macbook Pro running Sonoma 14.6.1
Sep 18, 2024 12:02 AM UTC
Thanks, @Stella2!
We have seen reports of Grammarly (or similar spellcheck apps/plugins) causing conflicts. If you have any of these installed, having them uninstalled or de-activated may be a good 1st troubleshooting step to check if they’re overriding our native spell check function.
Stella2
Sep 18, 2024 7:39 AM UTC
nope, no extensions impacting spelling 😦
Sep 18, 2024 6:55 PM UTC
Thanks for confirming, @Stella2!
Can you please try clearing your browser cache to see if that makes any difference?
We’re still not able to repro using the browser in FigJam. If clearing your browser cache doesn’t help, we may have to escalate this to our technical quality team to investigate further.
Stella2
Sep 19, 2024 4:35 AM UTC
no luck 😦 it doesn’t seem to be isolated to just one board either - looks to be across everything.
Sep 19, 2024 6:54 PM UTC
Thanks, @Stella2!
Let’s try one last troubleshooting tip…
Can you please try checking your OS System Settings > Keyboard > Input Sources - Edit… > Spelling, then toggle from “Automatic by Language” to “British English”?
Let us know if that helps!
Stella2
Sep 23, 2024 9:34 AM UTC
nope 😦 that didn’t work either
Sep 23, 2024 3:49 PM UTC
Thanks for trying, @Stella2!
I’ve created ticket #1130317 on your behalf with our technical quality team. Someone from the team will review what we’ve tried here then continue troubleshooting with you directly.
alexandre_truan
Sep 27, 2024 12:00 AM UTC
Hello, this same issue is happening to me. I tried all the troubleshoots and no luck. My available spell check languages are English and Russian. I do work in English and French and would like to add French.
I also went to change the language on my main page in settings and have the exact same options as Bjorn_Larson.
Did anyone figure out this issue?
robertorodriguez19
Oct 1, 2024 10:10 AM UTC
Hey guys i had the same issue, i speak spanish, i just added the language pack on windows in spanish just like the lady did an example for swedish, but after that it didnt work, i just restarted my computer and then it worked, so probably you just need to restart your pc aswell.
