Molly_Hellmuth
Aug 11, 2021 6:46 PM UTC
Every icon best practice you need to know
I’m a Figma tutor and get asked about icon best practices a LOT. I made this cheat sheet for my students and thought some designers here might find it helpful as well!
Icons are a foundational part of any design system. They’re tiny, language-independent, symbols that help us understand and navigate digital products. Each one acts as a small building block to create bigger, more complex components. In this article, we’ll go over how to set up your icons, use them in designs, and hand them off for development.
Before we get started, let’s go over the different types of icons.
Actionable icons: These icons are clickable and can trigger an action. They can open something, close something, or navigate the user to a new location.
Informational icons: These icons are not clickable. They describe or highlight information the user needs to know. They can replace text, add emphasis, or make a design more accessible.
Setting up icons
Create an organized, consistent set of icons before you start designing any other components in your design system. This speeds up your workflow, makes your designs more consistent, and enables you to scale your website or product.
Choose an icon library
For most web projects, we recommend using a large, established icon library. Obscure icon libraries usually have a limited selection with no icon font support. And creating your own custom icons takes a LOT of time and skill to get right.
Here’s a collection of established icon libraries with a large selection of SVG icons, multiple fill/stroke states, and font support. Choose one that best matches your brand.
Note: If you’re up to the challenge of making custom icons, Figma is a great place for it! Even the icon pro’s at Font Awesome prefer Figma to other vector drawing tools. But we still recommend icon libraries unless there’s a clear design use-case for custom icons.
Add icons to your Figma file
Add icons from the library you’ve selected as SVG files. This allows you to edit the icon’s vector color and size. Add the icons by downloading then dragging and dropping them into your file, or by selecting them in a plugin (most recommended).
a) Add downloaded icons
Download icons from the web onto your computer, then drag and drop them into your Figma file.
Download - C
b) Add icons from a Figma plugin
Install an icon plugin, open the plugin in your file, then drag and drop the icon(s) into your file.
Plugin - C
Customize icons
Customize icon size, color, and resizing behavior. This makes designing with your icons much faster because fewer overrides need to be made while designing. It also helps keep your designs consistent.
1) Size each icon
Once added, SVG icons will appear as a square frame with a vector inside. Resize each frame to match your default icon size. Choose a default icon size that is divisible by 4 or 8 so your icons will align with your base unit (e.g. 16x16, 20x20, 24x24).
Each frame should contain a small amount of internal padding on all sides (e.g. 2px). This ensures all icons appear evenly sized/spaced despite being different shapes. The same logic applies to adding more or less kerning around different type characters.
Pro tip: Use the plugin Icon Resizer to resize many icons at once.
Icon Resizer - C
2) Style each icon
Customize the fill color of every icon vector to match your branding. For example, update every icon from black to your default gray style. Also, update stateful icons to show their “active” color by default (e.g. radio buttons and checkboxes).
3) Set the resizing behavior
Set the constraints for every icon vector to “scale/scale” so it grows and shrinks along with the size of its frame. This way each icon can change size and maintain the perfect ratio between size and padding.
Scale - C
Turn into Main components
Turn every icon into a main component to use instances of them across your designs. This makes finding, adding, and swapping icons easier. It also makes bulk updates to your icons MUCH faster. For example, changing an icon’s color. Edit the one main component rather than hunting down every icon in your designs.
  1. Place all icons on a frame labeled “Icon”. This adds organization to your file. It also adds the same nesting hierarchy in the Asset Panel as writing “Icon/” at the beginning of every name.
  2. Name each icon (e.g. “Close”). Use the forward slash ("/") naming method for categories of icons (e.g. “Format/Bold”, “Format/Italic”)
  3. Select all icons and click “create multiple components” in the toolbar.
Pro tip: Combine like icons as variants for faster instance swapping and the ability to use Interactive Components. This is only recommended for icons that are part of a set (ie. up/down/left/right arrows), or icons that will have hover/click prototype behaviors (e.g. radio buttons). Learn more about using variants here.
Using Icons
Once your icons have been set up you’re ready to start using instances of them in your designs. They can be used as singular elements or nested inside larger components.
Add & swap icon instances
Instances are a copy of their main components. They can be found and added from the Asset Panel and swapped out in a number of different ways.
1) Add icon instance
Find the desired icon in the Asset Panel. From here, drag and drop an instance of it into your designs.
Add instance - C
2) Swap icon
Drag and drop the new icon over the original icon while holding the " option " key. Any style/size overrides to the original icon will persist.
Swap - C
3) Swap nested icon
Select the nested icon, then choose a new icon in the Instance Menu. Any style/size overrides to the original icon persist.
Swap 2 - C
4) Swap variant icon
Select the icon and update its type or state by choosing a different property value.
Variant - C
Apply overrides
Customize icon instances by applying size and color overrides. These overrides only affect the instance and do not update the main component. To apply overrides, edit the size of the icon or select the icon vector and choose a new fill color.
Pro tip: Select the nested vector shape in multiple icons by selecting all their frames and pressing " enter ". This will update your selection to only the nested children (vectors), and allow you to bulk edit color.
Override - C
Use icons as atoms
Use icons as atoms and nest them inside of other, more complex components. For example, nest an arrow icon inside of a button.
Pro tip: Give every nested icon a generic name. This way overrides will persist when swapping/configuring components in your designs. For example, name every right icon “Right Icon” in each button variant. When you change the state of a customized button, the icon type persists, and the color updates accordingly.
Developer handoff
When it’s time to handoff the designs, developers can inspect and export icons as needed from the Figma file. To make things even easier for them prepare the icon assets in advance. This can be done by exporting all the icons, creating a spritesheet, or using an icon font (most recommended).
Export icons
Export icons as an SVG, PNG, or JPEG. To export icons, select each of their frames and click the " + " symbol next to “Export” in the Design Panel. Then choose your preferred format and select " Export X layers ". Select the " + " symbol multiple times to export multiple different formats at once.
SVG is an XML-based vector graphic. It allows exports to have a transparent background and scale up/down without any loss of quality. SVGs can also be represented in scripts or code, making them the best choice for the web.
PNG is a lossless bitmap format. It allows the export to have a transparent background and maintain high quality when compressed. This is the next best choice for the web.
JPEG is a lossy compression of an image. It cannot have a transparent background and its dimensions are fixed making the quality lower. For this reason, it is not recommended for the web.
Spritesheet
Use an icon spritesheet if using multiple icons without an icon font for faster loading time. A spritesheet is a single image that includes all the icons in use with specific X and Y positions. These positions are then used to display the correct icon in the correct place.
Icon font
Using an icon font is the most recommended way to use icons. They take advantage of the typographic rendering capabilities of modern browsers. This allows developers to incorporate icons with only a few lines of code. It is easier, takes up less space, and looks great. When choosing an icon library, look for one with a supported icon font (see list above).
If you found this helpful, checkout some of my other guides: The UI Prep Blog
    KennLucas
    Oct 21, 2023 8:44 PM UTC
    Am I the only one that struggles with whether icon components need to be all the same consistent size or not?
    It seems that no matter how many things I try…IF I want to be able to swap icons, my icons need to be positioned inside of a same size component.
    In other words, if I have a circle icon that is 44px, everything is great. BUT, if I swap that icon for a chevron icon that is 44px x 24px, then the swapped icon STILL inherits the size set in the component (the one where the icon is used). This means my chevron is stretched tall to 44px x 44px instead of the correct size.
    My solution? Has always been that I make ALL icon comonents at 44px x 44px. And the chevron just gets centered in there.
    That works…or USED TO WORK? Now, with DevMode, when a developer inspects that icon, they are misled in seeing it as 44px x 44px. NOT the correct 44px 24px.
    No matter if the icon components and vectors in my library are all set to SCALE or not…it does not make a difference. And there is no alternative to “hug contents.” It is unclear, and anyone who writes articles and tutorials just glosses over this stuff and we are left to just figure it out.
    So which is it Figma? Do we make icon components all the same size? Or is there some magic way to make them stay scaled properly on swap?
    Al_Farabi
    Nov 28, 2023 8:44 AM UTC
    Hi, There
    One thing I would like to know what’s is best practice to add stoke inside, centre, Outside in ‘‘Outline icons’’?
    Gumilar_Adyana_Putra
    Nov 29, 2023 5:13 AM UTC
    In general, all icons should have the same size (visual boundary and padding area included) to ensure easier control on cases like this.
    For this case, you got it a bit backward; the component design should’ve respected the icon’s size first, as in adjust the rest of the component’s elements’ specifics (margins, spacing) to said icon.
    Unless, the use for that particular component was highly specific, like iOS’ back button in the navigation bar. The chevron/arrow icon itself is non-standard (as it was a font icon rather than a regular icon in the guideline), and it wasn’t used anywhere else; only in similiar usage of ‘back button’. For this, just separate the icon from the whole set and make a separate, specific component for that particular case.
    It depends on your styling, but in general, keep it in center since it’ll be much easier to control visually.
    Also, when you export it to SVG, by keeping it to center you can ensure that the strokes will be kept as strokes instead of shapes, thus minimizing its sizes and complexity.
    Franco_Bouzo
    Dec 14, 2023 2:05 PM UTC
    Hey there! I would like to know. Is there any reason why some libraries opt for not optically align the Chevron icons? I see that for example, on Google’s Material Symbols, they are not optically aligned (at least on Figma’s plugin, I noticed this detail by adding a fill to the 24px Icon and rounding it’s corners to 9999).
    I would like to know the reason if anyone knows. Is it a proper practice? or just google’s shenanigans?
    Evaluz
    Apr 3, 2024 10:59 AM UTC
    Hello Abraham!
    I am dealing with this question currently.
    I feel like Figma is stellar when dealing with outlined icons. I’ve always worked with outlined, flattened icons (24 and 16 since I need them in both sizes). However… there is a specific dev in the team who wants pixel perfect icons in both sizes so he demands outlined icons for the open source project.
    However… as you said, smaller icons can get hard to read if they’re reduced with the same line weight.
    What I’ve been doing is:
    • Outlined icons mostly, in two sizes: 16 and 24.
      Pros: Super easy to manage on Figma.
      Cons: some of them have weird lines when outlined + less “flexible” if their weight/design needs to be changed. According to the dev who required them: they’re not crisp enough since they might not sit perfectly on the grid.
    • Stroked icons are “crispier”, but are a PAIN to manage on Figma: since it is not a single vector, overwriting the colour values is very hard since some parts of the icon will fill with colour when it shouldn’t.
    So… I still haven’t find my answer lol. I guess that “it depends”?
    If you want to modify/adapt stroke is gold. If you’re sure you’re ready to roll with them and you will not change them, then flatten them.
    I hope I could help in some way.
    cmkaniac
    Sep 13, 2024 4:10 PM UTC
    Amazing post, thank you! My questions are about Material icons imported via the Material Symbols plug-in:
    1. My understanding is that one should create separate icon components for whatever icon sizes are needed in the system, because in the Material universe, the icons’ stroke widths, details, and proportions within the frame are optimized for a specific size. Because of this optimization, icons of the same type but different sizes are NOT simply scaled versions of one another. For example, a 24px delete icon and a 48px delete icon from the Material Icons library — each imported via the plug-in — are not resized versions of the same base icon. You can see this when downscaling a 48px icon and comparing it to a 24px version that was imported via the plug-in. The downscaled icon is thicker and larger. In other words, do NOT resize Material Icons imported via the plug-in, but rather create separate components for every size that is needed (e.g., 20px, 24px, 40px, 48px) for every icon type—is this correct?
    2. Because Material optimizes various icon details for a given size, I assume the default padding must also be left alone. The default padding ensures that different icons appear visually balanced and consistent, even when their shapes vary. Also, adding 2px padding around every icon then changes the icon dimensions to larger sizes (22px, 26px, 42px, 50px), none of which conform to an 8px-grid. Bottom line: the default padding of Material icons should be left alone —is this correct?
    3. Why does the Material Symbols plug-in import icons as groups rather than frames?
    mathilde_evens
    Nov 18, 2024 12:37 AM UTC
    Super interesting Molly!
    One thing came to my mind: How would you export icons in SVG with their padding area? on Figma (So I could export them in other softwares and they will have the same size)
    Nov 23, 2024 3:04 AM UTC
    To properly export icons with its padding as SVG, you should encapsulate it inside a Frame first as the bounding box (and for the SVG’s base dimension), then export the frame.
