Educational plan
  • September 23, 2024
  • 18 replies
  • 904 views
I am trying to apply for the educational plan. However, when I click on https://www.figma.com/education/apply, it shows me “you’re in” and “go to Figma” instead of application also the plan doesn’t change. I emailed support@figma.com, and they replied by stating that I should ask here in the community forum. Please help me out.
For your reference I have attached the screen.
Best answer by djv
Hey @Muhammad_Tayyeb, sorry for the trouble and confusion!
If your account has already been verified as EDU, select or create a new team to upgrade to Professional. From this page:
Select Upgrade to Professional. Then, you’ll see an option to select Yes for Is this an Education team? to the right.
djvSolution
Jeremy_Dennis
I am running into the same issue. However, I do not see the “free for students and educators” option shown in the image provided. I went through the entire payment process. Is Figma doing away with the free education plan?
Hi ​@Jeremy_Dennis, thanks for reaching out!
The previous screenshot and steps are outdated, which may be causing the confusion.
You can upgrade your team to the Education status by following these steps:
  1. From the file browser, switch to the team you’d like to upgrade and click All projects.
  2. Click the dropdown menu next to the team name and select View settings.
  3. Click the prompt to Upgrade your plan.
  5. In the summary on the right, select Yes for the Is this an Education team? option. ?name=inlineImage.png
  6. Click Next: Review.
  8. Figma will upgrade the team to an Education team.
Hope this helps! Please let me know if you run into any further issues.
Yana_Sakellion
Having the same issue with creating new teams.
Following the steps but do not see ‘educational’ option in step #5.
Hi ​@Yana_Sakellion, thanks for reaching out!
You mention creating new teams. Do you already have an existing EDU team?
Please note that with your EDU verification, you can only have one active EDU team, which would explain why you cannot upgrade any additional teams.
If you’re trying to create a new EDU team and do not have an existing team, can you please provide a screenshot of what you’re seeing on your end? We’ll pass this onto our team to investigate, as needed.
Yana_Sakellion
Hi ​@dvaliao , thank you so much for the prompt response.
A follow up question, please  - is this a new limitation?
In the past I was able to create multiple ‘edu’ teams for the different courses I teach. Because of the course level difference, it is really not an option to run a single team. Is there a suggested method to address this?
Hey ​@Yana_Sakellion, sorry for the confusion!
I was previously misinformed. Once your account has been verified, you can create as many Education teams as needed, but it does not make all of your teams education teams by default.
Is your issue only happening when you’re creating new teams? Or are you also having issues upgrading existing teams?
Kirrily Haskard
The instructions above seem outdated. I have been verified and clicked through the email but do not see any option to select “This is an Educational Team” on the right or anywhere else.
I have tried both upgrading an existing team and also creating a new one but see the same screen.
Kirrily Haskard
This seems to be working differently now. As there was a pop-up for educational plan in the left menu once approved and allowed me to then select the team to upgrade. Different to the instructions but I guess it worked eventually.
Yana_Sakellion
Hi again,  ​@dvaliao I am still not able to convert new teams to adu accounts. no pop-ups for me 😥
I have other ‘edu’ teams, but the new ones just won’t budge. Anyone who is verified found a workaround for this?
current teams
attempt to upgrade free test team
nope nope nope 😖
