Manuel_Barrio
October 19, 2022
Edit/select all with same text properties : unreliable
I’m trying to use edit/select all with same text properties to tidy up all my text but I’m getting mixed results. Often the highlighted elements only have the font in common (not even the font weight) or font size. This makes this feature completely pointless and I’m now having to check everything manually.
Is there a solution?
Bennett
February 27, 2024
This is because you have a text box with multiple properties within it (e.g. you might have bolded a word within a paragraph of regular weight text).
For it to work as intended, each text element must be uniform.
