Elly_A
Aug 7, 2026 3:53 PM UTC
Duplication of identical columns in Fig Buzz's Bulk Edit
Hi there, I’m troubleshooting building a suite of evergreen ad campaign assets in Buzz. The only things that should ever need to change are the copy for my offer and the brand logo featured.
As I poured over the assets from a prebuilt library, I’m noticing that some of the title copy (that will never need to be edited) has differentiated itself in the bulk edit spreadsheet, in spite of being identical to its siblings.
The right-hand column “flash offer” randoms should be living in the column to the left.
It doesn’t look like there’s a way for me to brute-force this by pasting them into the proper column. What could I have done wrong to make them separate like this, and how can I avoid it as I try to build this suite for my team? There are quite a few assets with this issue and I’d like to fix it entirely rather than just hide both columns. TIA
ksn
Aug 7, 2026 9:19 PM UTC
Hey ​@Elly_A - thanks for posting and checking in on this. Off the top of my head, I’m not sure on how to avoid/fix this 🤔 I’m checking in with the team that works on Buzz and will update you when I get more info!
Elly_A
Elly_AAuthor
Aug 10, 2026 2:05 PM UTC
Thank you!! FWIW I went back to those errant artboards and copied/pasted the headline from a “good” one, as if to replace it. It didn’t change anything unfortunately.
ksn
Aug 10, 2026 5:05 PM UTC
Hey ​@Elly_A! I just spoke with one of our engineers, and they would need to take a look at the file to see how the template is structured.
I can’t guarantee a quick resolution, but would you be willing to share a view-only copy of the template? I can forward that to them to review.
Elly_A
Elly_AAuthor
Aug 10, 2026 5:17 PM UTC
For sure. Just let me know who to add to the file.
ksn
Aug 10, 2026 5:21 PM UTC
You can share to support-share@figma.com -- if you can then provide me the name and direct link to the file (you can DM this to me or post it here), I’ll get this forwarded.
Thank you!
ksn
Aug 12, 2026 5:35 PM UTC
Hey ​@Elly_A - update for you:
I spoke with our engineering team, and one member mentioned that they found one of your styles has a layer group around everything except the 'Flash Offer' text node, while another one of your styles doesn't have that group at all. Since we generate column names based on layer hierarchy, Buzz sees those two setups as different, which is why it's placing them in separate columns.
Try modifying the layer group structure to be consistent across all of your styles — once the hierarchy matches, Buzz should those text nodes as the same and merge them into a single column. Let me know how it goes!
Javier Angulo
Sep 30, 2026 9:46 PM UTC
Hi Elly — I saw you’re building a suite of evergreen ad campaign assets in Buzz where the main editable content is the offer copy.
I recently built a small plugin for another problem that often shows up in exactly that kind of Bulk Edit workflow: longer copy overflowing the approved layout.
TextFit for Figma Buzz lets you freeze the original text area, then after editing or bulk-changing the copy it scans for overflow and automatically reduces the font size until it fits again.
It works on the current asset, selected assets, or all assets, and you can set a minimum font size.
It won’t solve the column/hierarchy issue in this thread, but it may be useful once you start generating lots of copy variants:
https://www.figma.com/community/plugin/1685810922519235112/textfit-for-figma-buzz
It has a 7-day full-feature free trial. I’m the developer, so I’d genuinely be interested in whether it helps with your campaign workflow.
