Mastro
Dropdown input overlay with variables
  • July 2, 2024
  • 144 views
Hi there, I’ve watched this helpful tutorial https://www.youtube.com/watch?v=DuJL8t4myms (building a dropdown with variables) and there are many more like this one, but none of the ones I’ve found take into account the fact that the dropdown, not being in overlay, when inserted into a page with other inputs tends to push the next element below. If you use the absolute positioning function or set the height of the instances for just the touch are, the dropdown instead will appear behind the next element as there is no control of the z-index. Does anyone know a solution for this case? Thank you
Vishal_Ramawat
July 3, 2024
You can reduce the height (bounds) of the Variant in the component.
If you can share your file/page that would be helpful.
