Zoe_Nguyen
September 23, 2022
Drag feature doesn't work on both directions
I expect to have two drag interactions which go to the left and right for a carousel. Unfortunately, only one direction works (to the right side). Is it a bug? Or how can I fix it?
Solowalker_Freeman
November 13, 2022
Having the same issue too, was thinking it was something to do with the way I set things up
SohrabNiroo
@Zoe_Nguyen @Solowalker_Freeman
Yea It’s on Figma unfortunately and I remember there is a Vote for it.
However, there is a workaround to achieve some smooth prototype.
Choose on drag / Set animation on Slide in / Choose 1 drag action to slide form right and 1 drag to slide left / set smart animate matching layers.
Super important: Set the name of similar layers, The same if you want this to work.
I hope this helps
I have attached a screenshot too
boris10
November 30, 2022
Thank you! I didn’t understand this: " Super important: Set the name of similar layers, The same if you want this to work.", but it worked out for me anyway.
I hate Figma wasted my time on trying to make its half-baked functionality work (and, probably, your time too!). So, thanks a lot again!
Jamie_McQuade
December 14, 2022
Workaround
I find that - even though its supposed to be able to - Figma can’t accurately discern between a left and right drag action when two are applied to the same carousel card.
So instead of selecting the entire carousel variant and trying to add multiple drag actions for the return drag to each one - select the actual carousel card (from inside the variant) for each step of the carousel.
Then you can sort of trick it into not duplicating the same drag action for each variant, because one of them sits on the individual card within the variant…
Clayton_Bach
January 7, 2023
This worked for me, thank you!!
Divya_Karuna
January 13, 2023
I found a trick to make this possible. I wanted the slider to move on both sides when you drag. So I duplicated the slider handle and grouped a transparent rectangle to each sides and smart animated it. Now it works like a charm. Let me know if this helps.
Julio_Neves
January 31, 2023
It’s works for me!
April 15, 2023
This worked. I was trying for a few minutes before I Googled it. Thanks!
June 20, 2023
Jamie you’re a wizard
Sash_ux
February 27, 2024
Hey sorry I did not understand “select the actual carousel card (from inside the variant)”…could you please explain?
