Drag direction up and down using variables and conditionals
  • June 30, 2023
  • 19 replies
  • 4643 views
halkiona
Hi,
I’m trying to create a temperature picker and recent variables launch hugely simplified the process. I previously has to create a variant for each temperature. I just created a conditional to increase and decrease the temperature. However, I can still only drag the value in one direction only, in this case increase only.
I added two drag interactions one for toggling the temperature up and one for toggling it down but the second one doesn’t work. Is there a way to set drag direction when using conditionals? If anyone has an idea, please let me know.
Thanks
tank666
  • June 30, 2023
To be able to drag in different directions, your component must have a draggable object that must extend beyond the component’s bounds.
Just follow this guide:
  1. Create a number variable;
  2. Create a component set containing 2 variants (Minus, Plus);
  3. Apply the variable from step 1 to the text layer of both variants;
  4. Create a rectangle that is 3px higher than your variant’s height;
  5. Put it in each variant;
  6. Set this rectangle to the following coordinates:
    • Minus variant:
      X = 0, Y = -1;
    • Plus variant:
      X = 0, Y = -2;
  7. Add 2 interactions to the rectangles with the “On drag” trigger:
    • Minus variant:
      On drag 1 › Set variable to decrease;
      On drag 2 › Set variable to increase and Change to Plus variant;
    • Plus variant:
      On drag 1 › Set variable to decrease and Change to Minus variant;
      On drag 2 › Set variable to increase.
halkiona
  • July 3, 2023
Thanks @tank666 for sharing this idea. It works but it’s not exactly what I’m looking for.
When I drag up for example, the whole component duplicates and moves up change to a minus variant.
I even tried to create a component using the temperatures box only but then it doesn’t work for some reason. The component needs to be able to collapse and expand as well. I found that conditionals inside components when I change the variant. Not sure if that’s a bug or not.
tank666
  • July 3, 2023
What I described above should work like this:
And your case, if I understand correctly, should work as a scrollable list-wheel?
Then you will need 5 variables and 3 variants, each of which should contain 5 items.
Duplicate the file from the link below to explore the interactions in more detail.
Figma – 3 Jul 23
halkiona
  • July 3, 2023
Perfect. That worked like a charm. Thanks so much for your help 😀
halkiona
  • July 6, 2023
Do you have any idea how to make it go in a loop? E.g. from 0 to 30 and then again 0. I tried different conditionals but I’m struggling which variable to use as a condition <=0 and >30.
tank666
  • July 6, 2023
Write conditions for each variable in both Minus and Plus variant interactions.
For example:
halkiona
  • July 7, 2023
I did what you said and it still goes below zero. Not sure why. Each conditional here has the same condition just for a different variable. And I did the same for Plus variant with minTemp and maxTemp reversed. minTemp is 0 and maxTemp is 30.
tank666
  • July 7, 2023
Could you share a link to the file?
halkiona
  • July 7, 2023
Hi,
See the file here:
Figma
I noticed it’s working when the increments are by 1 degree but when I change it to 0.2 it doesn’t work. That is odd. Why should a decimal make any difference to a mathematical formula?
tank666
  • July 7, 2023
Unfortunately, there are no tools for debugging variables in the prototype. So I had to go a little deeper.
I think this is due to the way Figma handles decimal numbers. Here are the values of the variables that are obtained using the API:
variables
To fix your prototype, change the == operator in the conditions to <=, >=. Also, in the interaction conditions of the Minus variant, instead of the “minTemp” variable, use another variable or a value of 0.15 or something like that.
Since the variables are currently in beta, various bugs and shortcomings are possible. I suggest you to share your feedback on variables and advanced prototyping.
  • December 7, 2023
Man your prototypes were awesome. I was wondering if there is a away, even if it’s by using a gross workaround, to have decimals in a number variable?
tank666
  • December 7, 2023
Yes, you can create a number variable with a decimal value. Just enter a period or comma (for example, .25; ,5; 1.4; 2,8).
You can also enter a fraction (for example, 1/10, etc.) and Figma will convert it to a decimal value.
Amalia2
  • April 2, 2024
I’m trying to use this but for a clock, and changing hours when it gets to 12, for it to change from AM to PM.
So what if I want a range, I want 7 AM-7 PM, on drag. Minutes don’t matter for this. I followed a tutorial for it to all change after a delay but not on drag and tried to combine it with this and got lost. Happy to share my Figma file with you.
tank666
  • April 3, 2024
In this case, you need to create a couple more variables and add additional conditionals.
For example:
Additional variables:
  • amPM string type;
  • toggle boolean type.
Conditionals:
  minHr = 1,
  maxHr = 12
// minus variant
if (currentTime == maxHr - minHr && amPM == "AM") {
  Set toggle to True
if (currentTime == maxHr - minHr && amPM == "PM") {
  Set toggle to False
// plus variant
if (currentTime == maxHr && amPM == "AM") {
  Set toggle to True
if (currentTime == maxHr && amPM == "PM") {
  Set toggle to False
// default variant
// After delay 1ms
if (toggle) {
  Set amPM to "PM"
else {
  Set amPM to "AM"
As a result, you should end up with something like this:
Amalia2
  • April 3, 2024
Do you have a link to the file? I also want from 7 AM to 7 PM.
tank666
  • April 4, 2024
I’ve added a page with this example to the source file (post №4).
Direct link to the design file page:
Figma – 3 Jul 23
The wheel picker component example can be dragged in both directions with an infinite loop of values ​​1-12, and the starting value does not matter here. In any case, you can edit the variable values ​​yourself so that the prototype starts with the value you need.
Amalia2
  • April 4, 2024
Thank you! How do I make it so it doesn’t go around in a circle? Like I want it to stop at 7 when i scroll up and stop at 7 when i scroll down?
I want the numbers to be
7
8
9
10
11
12
1
2
3
4
5
6
7,
but not be continuous scroll in a endless circle. Like scroll up in one direction and scroll down in one direction, when it passes 12, it changes from AM to PM
When right now if I set the min time to 7 and max to 12, the scroll is
7
8
9
10
11
12
7
8
9…
etc, is there also a way to fix that?
tank666
  • April 5, 2024
  • May 9, 2024
Hey, So I am trying to create a similar but a bit different interaction. I am trying to make a weight scale such that if I drag the scale the number above changes with it. I have attached an image for reference. I tried giving number variable and increasing it as I drag the scale but the scale and number increases unevenly. How can I make it move together like with each line it increases 0.1
