Brooke_Corcos
February 9, 2023
Developers seeing different font weight in Inspect panel than designers with editor access
  • February 9, 2023
  • 11 replies
  • 1530 views
Hi there! We ran into an issue where designers with editor access see one font weight in the inspect panel, but developers selecting the same text layer see a different font weight in the inspect panel. Any ideas regarding how or why this is happening, and which is correct?
Screenshots below (had to redact some info):
Developer view:
Editor view:
Thank you in advance for your help!
August 16, 2023
Does anyone also still have this issue? Because we do.
Amber_McLain
August 25, 2023
Yes it is occurring in our view as well. In a font we are using, our designers see 700 weight but in dev view it shows 600.
Carla_Januska
August 25, 2023
Hi, yes we see something similar.
I think it has to do with the font naming differences between font files for desktop (.otf) and server-side font files (.woff). Why font companies don’t reconcile all the weights with names is a mystery.
Angie_Meeker
January 31, 2024
Same here.
Matthew30
April 13, 2024
I am seeing this issue as well with most typefaces
Hi there! Thanks for flagging this. Is it happening with Museo Sans Font weight or any other fonts?
Please reach out to the support team directly with a copy of your file and indicates which Font you encounter that issue by filling this form here: https://help.figma.com/hc/en-us/requests/new Be sure to use your Figma account email, include a link to the file, and share it with support-share@figma.com, so we can take a closer look. Thank you!
June 11, 2024
I have the same issue. The designer see 300 and 500 but in dev view i see 400 and 600…
Hey @Max_Undurraga , thank you for flagging this. Which font do you encounter this issue?
I see in our backend that we have a current long standing bug for Museo Sans font that our engineering team is aware of.
As said, can you please also reach out to the support team directly with a copy of your file and indicates which Font you encounter that issue here: https://help.figma.com/hc/en-us/requests/new This will help our technical specialists to investigate further your issue. Thank you!
June 11, 2024
Hello @Celine_Figma , sorry i forgot that, it was with Museo Sans as well
I will surely reach out the support team as well
Brooke_Corcos
June 12, 2024
@Celine_Figma Hi there! I’m the original poster, and we have been having the issue with Tempo Std. Is this a bug that the team is aware of or should I submit a request?
