Rob_Marquardt
Jun 23, 2023 9:08 PM UTC
Dev Mode: Compose code language not showing gradient info
I have a frame with two gradients with multiple stops in each. In Dev Mode with the code set to SwiftUI, it shows the two LinearGradients with an array of stops for each. When I change the code to Compose, I get no mention of the gradients, just a couple lines for a Column arrangement and then literally // Child views.
This wasn’t the case prior to Dev Mode and now I’m having to ask my Android engineer to translate from the Swift values. Is this something that’s just not wired up yet?
(There’s a FigJam · Bugs tag but no Figma · Bugs?)
Rob_Marquardt
Jun 26, 2023 3:38 PM UTC
Example screenshots
Jun 27, 2023 9:03 AM UTC
Our team have encountered the same issue
Vianney_BERNET
Jul 11, 2023 2:19 PM UTC
Same here, it’s not showing the CSS code of linear-gradient anymore (for gradient text for instance).
Adriano_Varlotta
Jul 12, 2023 11:11 AM UTC
Not showing to me as well
Liz_Emmert
Jul 18, 2023 2:52 PM UTC
our team is experiencing the same issue with dev mode. would love to have this fixed as it’s necessary for our dev team to have access to this code!
Alex_Stoian
Nov 29, 2024 11:57 AM UTC
same here, the team has to match hex codes to our tokens manually and it’s quite annoying.
Figma design using local variables:
Dev mode shows only hex codes:
