Arthur_Arakelian
May 26, 2022 6:04 AM UTC
Customize "Fixed width" of the nested instance
Hey there 👋 …is there a way to set a custom “Fixed width” for a nested instance of the component?
currently i’m just creating other master component (just one level higher) with the necessary width, but i’d like to avoid this method as i have to create new master each time which i think is not a good solution. So i’d like to know if there any other optimal way to set custom width for the nested instance.
Isaiah_Goodfriend
May 9, 2024 2:40 PM UTC
Brilliant! Thanks for sharing this gem, Alice 👏
Pavlo_Kiselov
May 9, 2024 3:30 PM UTC
It’s definitely nice one. After some time I got something slightly better if you like. Instead of drilling down layers I found it’s more convenient to have configurable width property instead
This way I can quickly set the size of an element to a specific value.
Here how it works
On top level this is a container for anything I like, in this particular it’s a form element that sits inside auto sized container. There are two props, one is to select specific input type and another one to adjust the width
Form Control component fills the width
The most important part is a width component. It’s like size tokens in TailwindCSS
As you can see it’s exactly the same spacer. I just made bunch of them to get as many sizes as I need
Here is some live action
Yay or nay? )
Isaiah_Goodfriend
May 9, 2024 6:16 PM UTC
A nice touch for sure. I’m using this primarily to adjust table columns, which requires me to input the width values manually.
AlicePackard
Power Member
May 10, 2024 2:57 PM UTC
Pavlo, your implementation is excellent! Using a swap property (and not variants in a single component set) also ensures this is still a layer-efficient approach. Your solution is also great for a team that’s using pre-defined styles (like tailwind). Appreciate you taking the time to include all those screenshots and video recording, I think this will help lots of folks out who discover this thread 💪
I write about building excellent Figma components on my blog: https://alicepackarddesign.com/blog
Pavlo_Kiselov
May 10, 2024 3:21 PM UTC
Thanks Alice. This method found its way to many many components in our design system. And yes, it’s much more effective than variants indeed. Also it’s a treat for the devs, they know exactly how much space is required without digging down layers
AlicePackard
Power Member
May 10, 2024 3:22 PM UTC
Making devs happy is always a win 🥰
Peter_Tschann-Grimm
Jul 18, 2024 7:11 PM UTC
I cannot get this to work! I have the containers setup the same way but when I change the instance of the spacer, nothing happens. It stays the same default width 😦
Pavel_Kiselev
Power Member
Jul 18, 2024 9:32 PM UTC
Is your spacer set to hug contents sizing? The trick here is to have all spacers not a fix size, but have an element inside instead.
Peter_Tschann-Grimm
Jul 18, 2024 11:04 PM UTC
Thank you! I did! I didn’t realize it had to be with the horizontal gap as the thing that determines the width
