cbasmajian
Sep 16, 2024 5:39 PM UTC
Current best practices for creating components with dynamic children?
I’m porting an existing design system to Figma, and I’m wondering, what are the best practices in 2024 for building components with dynamic children? For example, a dropdown menu where one instance has options A, B, C, and another instance has options D, E, F, G, etc. Or, a resuable modal component.
Some UI Kits / design systems I’ve seen here require a component instance to be configured, then detached. Is this the standard approach?
Ashlee_Williams
Sep 16, 2024 7:05 PM UTC
What I’d do is create a dropdown component with the maximum possible number of options, then set a visibility variable on each option that allows them to be individually shown/hidden from each instance of the dropdown. That way if I only need options 1-6, I can turn off options 7-10.
