Vero5
Creating local tokens from library variables
  • April 30, 2024
  • 4 replies
  • 539 views
I’m managing a local design system for one workspace at my company, which is based on a global library managed by another team. My design system has some colours that are not part of the global library, so I’ve created the variables in our local library and am in the process of assigning tokens. However, I would like to be able to create tokens that refer to colour variables from the global library
Hypothetical example: Colour “sunny” in the global design system is mapped to “background-accent” token. In my local DS, I’d like to create a token called “notification” and have it refer to “sunny” so that if it changes, it’ll be reflected in my DS as well.
The global library (and many others) is enabled for the local DS I’m working on, and I can access its colours and text styles in the usual ways except when assigning tokens. It seems like I should be able to, according to the screenshot below, but no other libraries appear in the dropdown. Is this a bug or am I doing something wrong?
Vero5
Vero5Author
Adding another screenshot
Jeff_Waterfall
May 3, 2024
+1 - I also need to do the same. It’s odd that there’s an “All Libraries” select, but you can’t select a library…
Vero5
Vero5Author
Hey, I just found out in my case it’s because the global library isn’t using tokens yet for colours! They’re still on styles until Figma releases better multi-brand support. Maybe check if that’s the case with you?
Jeff_Waterfall
May 3, 2024
Thanks for the follow up. I will check with the other design team
