Carter_Xiao
February 10, 2023
Copy String to clipboard or Trigger download modal from Figma Widget?
  • February 10, 2023
  • 4 replies
  • 1811 views
Using property menu to call the function
Example output for string variable
Fruit
  Blue
   Blueberry
  Red
   Apple
    Fuji
  Yellow
   Banana
tank666
February 11, 2023
To copy something to the clipboard or bring up the download window, you need to open the UI, send a message to the UI, and then call the copy to clipboard or download file function.
Carter_Xiao
February 12, 2023
Thanks @tank666, I tried but seems it only works with elements inside the widget not the property menu item? If there’s a similar thing to navigator or via 3rd party library import which I could click to copy, that will be great, but probably doesn’t support yet.
tank666
February 12, 2023
It doesn’t matter. You can call showUI from both the widget UI and the properties menu. You are probably missing something.
If you can share the code it will help identify the issue.
navigator.clipboard doesn’t seem to be available, but you can use document.execCommand(). As for third-party libraries, I can’t help with that, so try looking for them yourself on GitHub.
Carter_Xiao
February 14, 2023
Thanks, I eventually solved it, the issue was I forgot to return a promise directly to the anonymous function, so this code works for me. exportMindmap() returns an HTML in string format without using a separate ui.html file
({propertyName, propertyValue}) => {
    if (propertyName === 'Export') {
      return new Promise((resolve) => {
        figma.showUI(exportMindmap(), {title: 'Copy to clipbord'})
