Dmitry_Avrov
Mar 7, 2023 11:48 AM UTC
Content jumps up and down with using of smart animate and AL
I use some components in footer, that have two states: collapsed and expanded. All components and the main frame have Auto Layout. When I click on the collapsed component in the prototype the screen jumps up and down before the list expands with animation.
As I understand, the problem is connected to constraints of the contents. When I choose Smart Animation, I can’t set checkbox “Preserve scroll position”, because there is no checkboxes.
When I choose “Instant” and choose the “Preserve scroll position” option everything works well. But I want to do it with animation.
drive.google.com
JonasB
Apr 8, 2024 12:17 PM UTC
I just had the same issue and what fixed it for me was checking auto-layout settings of all parent containers:
This seems to happen especially when you have your main frame set to autolayout for automatic height adjustment (so while designing it adapts it’s height automatically when adding new elements).
My structure was:
→ Main frame (mobile view, removed auto-layout from this for fix)
→ Content frame (Auto-Layout stacks vertically)
→ Fold-Out element (auto animation changes height, content folds out)
Shasta_McBride
May 21, 2024 12:13 AM UTC
Thank you! this worked to rename the page names as the same.
May 21, 2024 7:21 AM UTC
I had same issue with accordion, removing the auto layout really helps! And I don’t know why 🫠
SomethingFishy
Jun 7, 2024 9:19 PM UTC
Both “solutions” feel really hacky to me even if they do get rid of the jump.
A bunch of different frames with the same name, OR fixed height parent frame with all the guts of the nested content spilling forth.
So it’s basically picking the least objectionable of these problems:
  • confusing frame-naming convention
  • overflowing design
  • jumpy smart animation
Figma is lipstick on a broken box layout where component interactions dissolve on contact with other pages.
Suds_Creative_Team
Nov 8, 2024 7:16 PM UTC
Yeah but then when accordians are opened the main frame doesn’t stretch meaning the bottom accordians go outside the frame and are either clipped (with clipping on) or behind my next section (with clipping off)
Still doesn’t fix the issue that the entire space should stretch without the jump to the top.
LaszloV
Nov 21, 2024 11:33 AM UTC
A bit late to this topic I gather, but highly agree with this. It is immensely frustrating to deal with these problems, especially as a paid user, expecting complex conditional smart animations to work flawlessly. Not to mention how frustrating it is to present projects to clients.
This problem feels entirely like a case put on a lower shelve by the team Figma unfortunately - even though it’s tied to most of the paid functions -, I wish it would get prioritised over some of the needless changes that get reversed anyway recently.
One can only hope.
Usama_Iqbal
Feb 25, 2025 11:04 AM UTC
If you set the main frame containing the sections to a fixed width, such as 1440 x 1024, and enable scrolling within it, you won’t face this issue. However, if you set the main frame to "Hug" height, then naturally, when components like an accordion expand, the height of the main frame will also change. This causes the entire frame to readjust, which results in the content jumping back to the top.
To avoid this, it's recommended to use a fixed height with scrolling enabled rather than a dynamic height that adjusts with content expansion.
Gerard
Jul 3, 2025 2:31 PM UTC
I think I’ve figured it out. Well for me anyway.
On the parent frame/screen where the animated elements live set that parent frame to vertical scrolling within the prototype options.
I now have multiple animated expanding (up/down) sections within one screen and it works with smart animate.
Hope this helps.
