Components of Material Design Kit is not showing up under assets
  • May 7, 2024
  • 4 replies
  • 917 views
The components of Material Design Kit is not showing up under assets. I opened Material Design Kit in my project and published it.
I created a new design file and added “Material Design Kit” but no components are appearing under assets.
With other libraries this is working but not with “Material Design Kit”. What is going wrong?
Gayani_S
  • May 8, 2024
Hey @Reineke, thank you for reaching out!
Could you please confirm if the file “Material Design Kit” is published and is enabled for your current file?
Find more information on how to publish a library in our Help Center article: Publish a library
If so could you try unpublishing and then republishing the entire library? Note that doing so won’t break any existing connections with subscribed files.
Here’s how to re-publish a library file:
  1. Click on the library icon in the Assets panel to open the team library modal
  2. Click on the current file
  3. Click “Unpublish file” at the bottom of the modal
  4. Re-open the team library modal
  5. Click “Publish file”
If that doesn’t help, and even when the library is published again the component isn’t in the Assets panel, let’s try publishing a controlled update to the component instead:
  1. Go to the main component, apply a small change to a property of the component. For example, change the opacity or add a stroke - just something small that’s easy for you to remember and undo afterwards.
  2. Publish the update.
  3. Go to a subscribed file, accept library updates and see if the library remains up to date.
  4. Go back to the main component and reverse whatever test change was applied.
Let me know how this goes for you - if you continue having trouble here, I’ll be happy to get you connected to our technical quality team.
Gayani
  • May 8, 2024
thanks for the prompt answer. I do not have something like "unpublish file " is that dialog. I also recognized that I have this file 4 times within the dialog with always a different styles count (see screeshot).
Meanwhile I can add one of the 4 and this one appears unter assets. But the others I cannot load.
Gayani_S
  • May 9, 2024
Hey @Reineke, thanks for checking! Hmm I am unsure here, let me ask the team internally if they can help out. I’ll get back to you once I receive a response from them.
Appreciate your patience in the meantime!
Gayani_S
  • May 15, 2024
Hey @Reineke, apologies for the delayed response! Our team is assuming that the duplication is coming from the fact that it’s a Community file - these won’t automatically update when the new components are added to it.
We’d need if possible files access and a screen recoding showing which libraries working correctly and which not. When providing file access please invite support-share@figma.com with “can edit” permission so we can look into this further? Note that users with @figma.com emails on your team do not count towards your billing.
I’ve just created a support ticket on your behalf. Your ticket number is, #1002018 for reference!
You’ve mentioned “I can add one of the 4 and this one appears unter assets. But the others I cannot load.” - can you please also clarify to our support team which one is loading and which one isn’t?
Let me know if you have any further questions, happy to help out!
