Ish
Mar 23, 2022 3:19 PM UTC
Component not found when swapping identical library
I could only find one similar query and it was auto-closed with no answers. I have cloned a library and I’m swapping a file to that library so I can test component changes non-destructively.
It is a straight clone, no changes at all have yet been made. Not to naming, position, theme, anything.
Several components are not found after swapping the library. I can find them myself in the file, they exist and are named as expected, but the built in swap insists they do not.
This is clearly a bug, has anyone found a way around it?
Erico_Nascimento
Dec 5, 2023 7:24 PM UTC
Checking if anybody had a fix for this I’m having the same issue swapping between material icon and annotation kit libraries
Mar 14, 2024 4:07 PM UTC
Facing same issue here
Mar 18, 2024 5:51 AM UTC
Thanks for bringing this to our attention. If you encounter this unexpected behavior again, could you please file a bug report following the guide below?
Figma Learn - Help Center
Toku
MoOrEz
Jan 20, 2025 4:31 PM UTC
Same problem here,
very annoying, very time consuming and it’s having a huge impact on my delivery.
:S
