Component instance behaves differently than the component
  • March 26, 2024
  • 712 views
As you can see in the video the component, instance behaves differently than the component. Is this a bug?
  • March 28, 2024
Hey there,
Probably this one is a known feature limitation and there is a workaround as shown below:
Could you try this out? If the issue persists, would you be able to share the file link with access to support-share@figma.com? It won’t affect your billing. I hope I can investigate it further.
Toku
  • April 1, 2024
Thank you. I added auto layout to the collapsed and expanded components inside the main component and set the resizing as you mentioned and it fixed the issue.
