Kindstrand_Linus
May 23, 2025 1:16 PM UTC
Color Variable Reset When Switching Icon Variants in Component Instances
Hey everyone!
Our team has built a multi-brand design system that supports three different brand themes, each with both light and dark modes.
All our icons are created as unions. This helps preserve the color override when an icon is swapped inside a component. For example: all icons use the “icon” color variable by default, but within a success inline message component, the icon is overridden with the “icon-success” color variable (green), as the icon should always be green in that context. Swapping, say, a checkmark icon with “icon-success” applied for a shield icon retains the correct “icon-success” variable. So far, so good.
However, when we re-theme the inline message component from Brand 1 to Brand 2, the icon switches to a different brand-specific variant from the icon component set. Here’s where things break: in component instances, the color override (“icon-success”) is lost during this brand switch, and the icon falls back to the default “icon” color variable — which in our case is black. This results in applications where everything re-themes correctly except the icons, which suddenly appear in the wrong color.
We understand this is technically an override, and that swapping icon variants may reset such overrides. But the odd part is: this issue only occurs in component instances. In base components or standalone frames, re-theming works as expected and color overrides persist across variants. It's only in instances that the override is stripped out.
I’ve attached a video showing the issue in action. We’d love any guidance, workarounds, or insights into this — but ideally, we’re hoping for a native Figma fix, as this seems to be an inconsistency in how theming is applied to instances vs. base components.
Thanks in advance!
y_tokuSolution
Jun 5, 2025 5:06 AM UTC
Hi there,
Thank you for bringing this issue to our attention, and I apologize for the inconvenience you're experiencing!
After checking our internal system, I found a potentially similar issue that's already been reported to our engineering team (regarding color overrides not being preserved after instance swap).
I've flagged your case internally with a reference to this existing issue. However, if your specific problem turns out to be different, our engineering team would need more details about your particular situation to properly investigate.
Could you please submit a formal bug report with detailed reproduction steps? This would ensure our engineers have all the information they need to address your specific issue: https://help.figma.com/hc/en-us/articles/360041468234-Submit-a-bug-report
Thanks for your patience,
Toku
y_tokuSolution
Hi there,
Toku
Lili S
Jul 16, 2025 2:58 PM UTC
Please fix this. It is extremely annoying.
Alexander Danling
Aug 26, 2025 8:47 PM UTC
Can confirm we have the exact same issue as Kindstrand_Linus, and it drives us insane.
Tereza Antunes
Oct 7, 2025 8:06 AM UTC
The company I work on is transitioning to Figma variables and I honestly spend hours trying to fix this problem thinking that I wasn’t doing it properly.
Also, when changing modes on my icons from default to in-button, the in-button variant is not overriding the default mode.
Please fix this!
Kindstrand_Linus
Oct 7, 2025 8:14 AM UTC
Hi there,
Toku
I can, for a status update, inform anyone reading this thread that I have made a formal bug request to Figma regarding this problem but I still have not received any information about if they are planning to fix this or not.
Kindstrand_Linus
Dec 5, 2025 8:38 AM UTC
Problem is finally fixed!
Thanks Figma
Deepanshi
Dec 16, 2025 6:34 AM UTC
I am still having this issue. When I change the button mode for the size, in two of the modes, the icon color is not coming as per the variable set for the icon. It is breaking to the original Icon component color.
For example this is the disabled state of 4 sizes(set up using modes) of the button. In two of the sizes, the icon color is correct, but in the other two it is getting overrides with the original icon component color.
Any workaround for this?
Jan Søholm Knudsen
Dec 18, 2025 10:26 AM UTC
Thanks Figma
I have the same issue, and it still persists. Seeing that @Kindstrand_Linus has gotten the issue solved, is it just a matter of waiting for an update, or are there any steps we can do?
ramzi ltt
Dec 25, 2025 11:04 AM UTC
I have the same problem when I try to change the colour of the main component icon. Although it changes the colour of the icon, it does not change the colour of the swapping icons.
Oleksandra_Koval
Apr 2, 2026 9:15 AM UTC
Hi there! Is there any update on this issue? It's really hard to work with this bug.
