Pauline A.
Jan 5, 2026 4:55 PM UTC
Code Connect validation fails when emoji in component property name
Hi all,
I have a problem when trying to publish code connect file because the component has a property with an emoji character in its name: ✏️ Label
Error is “Validation failed for ...: The property does not exist on the Figma component.”
It’s a Compose project.
In @FigmaProperty value, I tried to use “✏\uFE0F Label”, “\uFE0F Label”, “✏ Label”, “Label”, but nothing works…
Does someone have an solution for this issue?
Thank you for your help.
Pauline A.
Jan 5, 2026 5:05 PM UTC
I found a solution. It was a problem with my IDE (Android Studio) when I copied/pasted the pencil. I fixed the issue by using another IDE for copy/past 😅 It works now!
