Chris3Ds
Feb 20, 2025 4:57 PM UTC
Choosing which properties of the nested instances we want to display on the children instance
Hello,
I have list of 3 same components and i want with the nested instance to show only the Label properties and not the whole list (2 Variants,1 boolean and the label input)
Does Figma allow to show 1 property among the whole list ?
Thank you !
Apolline
ApollineSolution
Feb 24, 2025 10:57 AM UTC
No, it’s impossible
You can upvote this topic asking for this functionality
Franco Tirabasso
Feb 21, 2025 12:53 AM UTC
Hey Chris,
Can you share some screenshot(s) of what you have and a more detailed explanation of the desired outcome?
Chris3Ds
Chris3DsAuthor
Feb 21, 2025 9:16 AM UTC
Hello Franco,
Thanks for your reply,
I have this 3 CTA “Valide Return Cancel” and what i need is to show in the right panel is only the Button text property and not the design or the state properties.
Do you know if we can select witch properties can be shown at the right panel on a nested instance ?
Franco Tirabasso
Feb 21, 2025 1:06 PM UTC
If I understood correctly, what you are asking is to handle only the state of the button within a nested instance. It would look like this.
It that’s the case, you need to
  1. Create a component set of your buttons with only one “State” property:
  1. Insert of those buttons you created as an instance inside your parent component. Then create a property on the parent component exposing a nested property from the button.
Let me know if that worked for you.
Chris3Ds
Chris3DsAuthor
Feb 24, 2025 10:32 AM UTC
I thought my message was send,
I need to have these 3 properties on my button properties.
Are there not alternative to show only selected properties from the user among the entire property list ?
Apolline
ApollineSolution
No, it’s impossible
