solmaz_cheraghi
Apr 22, 2024 7:33 PM UTC
I have same problem why color of swap instance doesn’t change color when ever i change color of swap instance in main component?so i upload my Figma file for considering.thank you.
test.fig (184.6 KB).
Apr 23, 2024 3:30 AM UTC
Thanks for flagging. This could be a potential bug, so we shared internally. When there is anything I can share with you, I will get back to you.
Thanks for your patience.
Toku
Jun 15, 2024 7:01 PM UTC
This is a huge problem for us. Components like sidebar navigation, icon button where teams often change the icon at instance level are not getting updated. Recently we moved colors from styles to variables, and this created a huge debt for product teams, now they’ll have to manually go an update each instance, otherwise dark mode will not work for them.
Please fix this.
ksn
Jun 17, 2024 2:40 PM UTC
Hey @Aman_Rathi1 I’m sorry that this has been a disruption to your work. I know that there is a bug ticket for this, but I don’t have a specific timeline available on when this will be addressed.
Thank you for your patience.
leonsholo
Oct 7, 2024 8:22 PM UTC
So for me, the icons to the sidebar menu were the ones not reflecting the colour of the actual component, so this is what I did: I had to create a new component with new icons and replace the initial ones I chose and that actually worked.
click_Mao
Jan 22, 2025 5:27 AM UTC
Has it been fixed? Some of my components and instances change color normally, some don't, but their drawing rules are the same.
Patrick Voet
Feb 13, 2025 9:36 AM UTC
Manual workaround is to add another variant, with property true/false (e.g. “Outline button: True/False”). After you change this property to false and then back to true color of icon will change to correct (updated) color.
Cheers for that, I had this issue popping up, and gave your potential fix a try, worked a charm!
Cedric_DELMOTTE
Mar 19, 2025 4:27 PM UTC
Hi, same problem for me, every day! I have to reset components and re-embed all my icons and texts so that my instances return to the desired colors. It's unbearable and a significant waste of time every day.
