Mark_Steinruck
Apr 28, 2025 8:55 PM UTC
Changes to library but we didn't do anything
Our team is noticing that our main design system library is having hundreds of changes flagged in the publishing panel, even after a weekend of not working on the library. The panel shows what’s modified, removed, or added, but isn’t clear what the changes are or what caused them. It’s scary publishing these types of updates because they aren’t coming from our team. Is this something being caused by Figma? How can we feel comfortable publishing so many changes when we weren’t even the ones making them?
    May 2, 2025 4:47 AM UTC
    Hi ​@Mark_Steinruck
    Thanks for flagging. I can definitely see how getting unexpected notifications could be a bit unsettling. Would you mind submitting a bug report by following this article: https://help.figma.com/hc/en-us/articles/360041468234-Submit-a-bug-report? That way, our support team can take a closer look and get to the bottom of what's happening
    Thanks for your patience.
    Toku
    Mihailo Jancic
    Oct 1, 2025 6:51 AM UTC
    Hi ​@Mark_Steinruck has this issue been resolved to you? Im building design system and i have the same problem, it feels very strange. Even on other files i get notified to publish something that i changed like 10 days ago but already have published multiple times in the meantime.
    Mark_Steinruck
    Oct 1, 2025 12:54 PM UTC
    Hey ​@Mihailo Jancic, no it’s still doing the same thing as before. It wouldn’t bother me so much if there was some type of log indicating what changed, but it’s completely obscure and continues to happen without warning.
    Esther_Wiest
    Nov 18, 2025 3:31 PM UTC
    Hello ! I have the same problem too. In the library file, Figma proposes to publish changes in components that haven’t been modified by anyone.
    Set apart the bug itself, it would be great to have, when you publish the library, a quick resume about what has changed in the component. The same we have in the project files, when we update the components based on the last library publication. It would be useful to review the component modification one last time before publishing.
    Lucas Cámpora
    Jan 28, 2026 1:51 PM UTC
    Hi! Same issue here. Any fix?
    Stefan HM
    Mar 31, 2026 8:20 AM UTC
    Just switched from AdobeXD to Figma, bought the UntitledUI Kit and have the same problem :-(.
    Published the UntitledUI LITE Kit and as soon as it’s done it already tells me I need to publish 450 changes.
    Obviously I didn´t change a thing.
    Fresh desktop install, fresh UI Kit and it behaves very strange (at least from a newby perspective)
    adamsmasher
    Apr 2, 2026 4:13 PM UTC
    Hi ​@Stefan HM!
    Thanks for your reply - I can see how that is confusing for you. This was a known bug and our engineers pushed out a fix earlier today so it should be fully resolved soon. Please refresh your tabs and let us know if you still see this happening. If you do, please share your impacted file(s) with support-share@figma.com and grant "Can View" access, and we can flag this to the team.
    If you have any other questions let me know!
    Jes Chuhta
    Apr 15, 2026 6:37 PM UTC
    Is this fix live for everyone? My team and I are still running into this issue.
    adamsmasher
    Apr 16, 2026 9:10 PM UTC
    Thanks for your reply, ​@Jes Chuhta! I’m sorry to hear you ran into this.
    I want to clarify this a bit more with you so I know if it’s the same issue or a slightly similar one. Have you tried publishing the changes, and if you do, are you still seeing the same changes listed for publishing again? The fix should be live for everyone, so the same issue shouldn’t be affecting you.
    One other thing to note is is how Figma treats core primitives. When an asset like a variable, style, or low-level component is modified, anything that depends on it (even transitively) is considered changed. Because of that, it can result in many updates appearing and becoming eligible for republishing. In more complex systems, it can be more unexpected when these publish updates show up.
    Generally speaking, it’s good practice to publish changes so everything is up-to-date, though I can definitely understand why you would be hesitant when you aren’t sure what those changes are.
    Yoki Tyas
    Jun 9, 2026 2:24 PM UTC
    Hi ​@adamsmasher,
    The same issue is still happening for me and the rest of the team for months now.
    The changes were made to a completely different atom component and are not related to any other atom components. No shared variables, styles, or other dependencies were modified.
    However, unrelated components are still showing the "Publish changes" even though no changes were made to them. For example, if I update the Tabs atom component, components such as Button, Tooltip, and several others are also marked as requiring publication. This behavior is becoming quite frustrating.
    I've tried every workaround I can think of, including:
    • Reloading Figma tab
    • Closing and reopening the file
    • Restarting Figma before commit to “Publish changes”
    • Making a small "fake" edit and republishing the affected components
    Unfortunately, the issue still there.
