Martin_Marinov
Jan 29, 2024 7:58 PM UTC
Change variant on resizing a component
Hey all. I was wondering is it possible to use min and max width/height of an component and use it for trigger to change a variant. For example: I have a proerty Size, and I have a component with 3 sizes. I want whaen I use the component when resizing it to automatically switch to 1 of the 3 sizes using height/width as a trigger. Is this possible.
Ellwood
Aug 20, 2024 12:56 PM UTC
You certainly can!
If your component has 3 size variants, say Desktop, Tablet and Mobile and you have a page / frame that you want to adjust across the device widths without having to individually change each component within… You can create a page width variable (screen-size) with different modes as above (Large, Medium, Small) to correspond to your defined breakpoints.
Screenshot 2024-08-20 at 13.50.04
If your component variable uses the same values, i.e. Desktop, Tablet, Mobile you can map the components state to use the same variable as the frame (screen-size). This way, when you change the frame size it automatically changes all the components in the frame to use the same variant ie Desktop, Tablet or Mobile.
Screenshot 2024-08-20 at 13.53.33
Hope this helps.
Aug 21, 2024 5:53 PM UTC
How did you monitor the component width? Can you show more detail?
Ellwood
Aug 22, 2024 8:41 AM UTC
You don’t need to monitor component widths, as the component variant is mapped to the screen-width variable.
So, on my design frame I assign min and max width variables plus assign the screen-size var to the frame. This allows me to adjust the frames width within the breakpoints. ie. if I select desktop the frame can be resized from 991px to 4000px and the screen-size var == large.
Screenshot 2024-08-22 at 09.36.12
Now, if the components used within the frame also reference the screen-size var to determine which variant they display then you are controlling all the components with one frame option.
Hope that helps.
Aug 22, 2024 3:01 PM UTC
I see how this would work if you manual change the “Sizing” mode of a frame but what about for a responsive prototype that gets resized?
Ellwood
Aug 23, 2024 9:54 AM UTC
I see what you’re getting at. I’ll take a little time to look into it more but as far as I know this is the easiest way to implement something close to it.
I don’t think there’s a feedback mechanism to get the frame width and push it to a variable you could use to control the component variant states, but I think that would be the ideal solution.
