Mathy_Lippens
Aug 20, 2024 7:17 AM UTC
Change instance state based on other instance state with conditional variables
I’m trying to create a Figma prototype of a form with specific functionality.
This is a multiselect form that exists out 6 of the same instances. This component this instance comes from has 4 states:
  • Default
  • Active
  • Hover
  • Disabled
What I need to happen is that when a user selects ‘No preference’ all other selected options need to be turned off (aka set to ‘Default’). What also needs to happen is if ‘No preference’ is set to ‘Active’ and another option is selected, the ‘No Preference’ option needs to be turned off (aka set to ‘Default’).
In short, ‘No preference’ can never be used in combination with any of the other options but the other options should be selectable with each other…
Anybody can help me figure out how to get this working?
Raphael_M
Power Member
Aug 20, 2024 10:12 AM UTC
You can do conditional (check if/else) with variables for this one.
Make sure to create variables for each card and attach it to your component that sets it to
selected variant:
The technique is to add this condition on the no preference that sets all the other cards to false and for it’s variable to true
And then add this to all other cards aside from no preference that sets the no preference variable to false
It should work like this:
