Bruno31
Feb 19, 2026 4:28 PM UTC
Change images with Variable mode (example with video)
Hey,
I just found through this video https://youtu.be/GbfUHfCocIY?t=802 that’s possible to change images by changing variable modes. At some point in the video (minute 18:17) we can see a string variable “Team ID” which is probably what he’s using in the images properties. But we don’t manage to see how he’s applying it.
First of, I can only apply the variable to an instance, not the actual component. I tried to do that and then from that instance create a new component, it does seem over engineered, but it does work. However I have an issue where if I change the mode once, it works, but if I try to change again it doesn’t work.
So I’m not sure what would be the right way to replicate what’s in the video.
Any thoughts?
