bld_design
Jul 23, 2024 7:58 AM UTC
Change icon colour in hover state
Hello Figma community!
I have a question about hover button state and icons. I have a component set of buttons in different states, and separately I have icons as components that I can use in button instances. However when I change a button icon in one, it doesn’t follow the colour change. How can I fix that?
Here is some pictures to show what I mean^
Components:
Button in action after icon was changed in the instance:
figma button issue
CoreyLewis
Sep 23, 2024 9:33 AM UTC
I was experiencing the exact same issue where stroke icons would not change color on hover. Another issue I had was that some paths of my stroked icon would change colors while others wouldn’t, for instance an “x” with 2 separate paths. One stroke line would change while the other remained the same. Don’t ask me why 🤷 But what a sick joke.
While the solution @Maxence suggested (good workaround Maxence!) is a good workaround, I discovered that my issue was due to how I originally imported my icons from the start.
I used the Lucide icon library (https://lucide.dev/) for my project. At first I used their browser solution to manually copy/paste my arrows as SVGs into Figma. I then discovered they had a Figma plugin (https://www.figma.com/community/plugin/939567362549682242/lucide-icons) where I proceeded to add all additional icons, which was a much easier process.
In prototype mode, some icons changed color on hover as expected, while others did not. I discovered the issue was with arrow icons copied from the browser. Icons imported using the Lucide plugin behaved correctly. After updating all icons utilizing the plugin, the clouds parted, a heavenly choir burst into song, and just like that, problem solved! 🥳
Hope this helps! 😁
