Jones Prabu
Jul 24, 2026 7:53 AM UTC
Challenge in figma-mcp to get the details of the main design system components from the Designed Pages.
Hello There,
Need help in make the figma-mcp to provide the components details.
We are using a Design System and using those DS components we are designing our pages, As a frontend developer using claude to to connect with figma mcp and do the frontend development. I am not getting the details of the components in the page like variants, size, which are the properties defined in the Design System.
Without much knwoledge about figma and did an analysis with claude and come to know the desing in the page has overwritten in the instances so it is differ from the main component, the figma-mcp will give a flat data instead of the properties choosen in that component. Also we can see there is a ‘i’ icon with the information in the figma that, “The border, text and layout in this instance differ from the main component.”
When we connected with the designers, they are expressing that it is not possible.
“It isn't feasible because the DS master components are designed with all possible variants. When we use those components (instances) in feature designs, we naturally override properties such as text, icons, toggles, and other content. So it's expected that the instance won't exactly match the main component.”
I want to get help and clarity from the designer community, is this a real challenge in figma and is there any solutions to make it work?
As a prompt engineer to make claude work better, We need those “button/tab/input/menu/pop-up/….” components actual selected variant type, style etc.., details so Claude can map and pick the right web componects  from our UI Design System library and set the neccessary properties by itself. Now we need to do a lot of manual work of instructing claude to chose those properties by prompting manually.
Any help to solve this highly appreciated. Glad to recive any other alternative way to try out as well.
PS: We use professional full seat by Designers and Dev seat by Developers.
Jaycee Lewis
Jul 24, 2026 4:39 PM UTC
Hi ​@Jones Prabu 👋 Thanks for the excellent post and questions. Let’s dig in.
The short answer is: you're both right. Your designers are correct that instance overrides are a normal part of using a design system, and you've correctly spotted that the MCP server isn't handing Claude the component/variant details you need. Those two things aren't in conflict — they're about different layers, which is where the confusion is coming from.
Why you're seeing flat data
The MCP gap you're running into is separate from your designers' point, which is just that overriding text, icons, and toggles on instances is exactly how instances are meant to be used. Both are true at once.
One fix: Code Connect
Code Connect is built for this. When a frame has Code Connect–linked components, the MCP output adds the current property values, import statements, and a usage snippet pointing at your real code. This lets Claude pick the right design system component and set props itself, instead of hand-instructing every time:
Two setup paths:
The honest catch: your plan
You mentioned having Full seats on a Professional plan. Code Connect requires an Organization or Enterprise plan (plus a Full or Dev seat) It isn't available on a Professional plan. If you'd like more information on upgrading, please let me know.
Your instinct that this is a prompt-engineering problem is the right lever without Code Connect:
Have fun building!—Jaycee
