Apr 5, 2023 5:40 PM UTC
Can't copy images from Google Slides into Figma?
I can’t copy images from Google Slides into Figma. I didn’t find any solved issue like this.
Yash_jain
Yash_jainSolution
Apr 5, 2023 7:25 PM UTC
You can’t copy images from google slides to anything. Try doing this right click image on google slides and save to google keep. (If the save to keep option doesn’t show up, add the app to slides.) From keep, you can right click the image and copy → paste to figma.
Yash_jain
Yash_jainSolution
Don_Correa
Apr 2, 2024 8:32 PM UTC
You could copy images from Google Slides to Jamboard. Figma should enable this feature.
Prashant_Khatri
Aug 6, 2024 9:26 PM UTC
What I found better is to go to the slide and then File → Download → Scalable Vector Graphis (.svg, current slide). You can then export that .svg slide to your Figma
valerie11
Sep 12, 2024 8:02 AM UTC
Yes going to slide and then File → Download → Scalable Vector Graphics (.svg, current slide) works, however its very time consuming as it only download per slides contents and in my case all the editable copies automatically pathed causing more work to edit.
