Jason Melgoza
Jun 1, 2025 5:48 PM UTC
Can I run downloaded projects from Figma Make locally?
Download code button
I spotted the "Download Code" option in the upper right corner of the editor, but I noticed that there is no "package.json" file. Is there any documentation or a way to run these projects locally using my own IDE?
buildr
Jul 24, 2025 2:28 PM UTC
Hi frustrated fam, i made a quick vsix extension based on the above repo and a few tweaks. Install in your fave IDE and CMD+SHIFT+P Figma Make add…. and select the zip file. Happy coding :) https://github.com/spetro511/figma-make-scaffolder
Quazar Dream
Aug 6, 2025 3:00 PM UTC
Beside truncating all versions from the imports by using https://github.com/likang/figma-make-local-runner  , make sure that you have tailwindcss enabled in your styles. E.g add @import "tailwindcss"; to the top of your globals.css
Bryce_Driesenga
Aug 6, 2025 3:07 PM UTC
Good tip!
​@buildr, maybe your extension could add this if it doesn’t already?
SandroB
Aug 17, 2025 12:28 PM UTC
I was about to leave to lovable even though I’ve invested some time in improving my website. Because neither asking Figma make for the config files not the figma-make-local-runner worked. In the end it was just about using node 22 (instead of node 18 or 20) together with figma-make-local-runner.
Naveen P
Oct 12, 2025 5:52 AM UTC
This combination worked for me perfectly. Thanks to all who contributed for getting this to work. (My node was already at 22).
