May 21, 2024 5:38 PM UTC
Can I create prototypes that are responsive?
Hi all,
I’m 2 weeks in learning Figma so bear with me,
I just finished designing a home page with prototypes and all. It was approved and I got the go to make the thing responsive for tablet and mobile.
I tried to educate myself as much as I could on auto layout, constraints and all, but it seems like when I create a component that has instances and I put them into a auto layout, it doesn’t work as it should.
It seems like if I want to use the same prototyped animation for desktop, tablet and mobile I need to recreate that prototype for each version? It seems like too much work.
My example is:
I Created a slideshow for the showcase section of the website.
My slideshow is made of 5 images inside a auto layout, inside a frame that are turned into a component.
The frame acts as a clipping mask to show only one picture at a time.
I then created variants of this component showing different pictures each time. The prototype is set on a delay, and auto animates to switch picture automatically.
This works like a charm so far, but when I try to change the constrain of the child to scale, the parent height switches to fixed and I can’t resize properly.
I hope this makes sense to someone, if someone needs pictures of the stuff let me know and I will provide.
Thank you,
mattaningram
mattaningramSolution
May 21, 2024 6:50 PM UTC
Unfortunately this is not possible in Figma.
Figma does not use real responsive design the way the web does. At most Figma can set min/max widths for specific elements or components, but there are no media-queries, breakpoints, percentage based widths, conditional visibility, or anything like that which you would need to design proper responsive layouts. Additionally prototypes are not resizable outside of resizing the entire window (the prototype scales with it) and thus are not capable of responsive design either.
Basically for responsive design you have to design entirely separate frames at different screen sizes and each one needs its own prototype setup.
One more reason I am beginning to design more and more in Framer or straight in HTML/CSS instead of Figma.
Josh_Madrid
Nov 28, 2024 5:28 PM UTC
Paul_Palade, It is better but there are some key things missing.
We would need a way to preserve aspect ratios of frames that are not hacky, Percentages as values, and Frame Breakpoints (not variables) that we can set based on the width.
So Frame Breakpoint would be set under the frame in the right panels and have an array of breakpoints you can add, and when the frame gets to a certain width, it applies the settings below panels (autolayout, fill, stroke, effects, position, etc… ). Ideally, it will always default to global, and then a user can add a new one below the frame.
Aspect-ratio is nice to force display flex to act in certain ways for a grid-like experience.
Percentages would be good for layouts that don’t have equal columns.
