KatK
Cache & lagging issues with libraries
Hey i hope anyone has some tips for me.
I’ve been working with the windows app since january and experienced cache issues when making changes in the library and publishing to working files.
Recently i split the components library up into 2 files, 1 for variables and 1 for components. We are running a multibrand design system and it was starting to get unweildy with just one library file. All ok there.
So the structure is:
  1. variable library
  2. components library pulling in variables
  3. consuming working file linking to both libraries
All of our components are built using atoms and nesting. But even just placing a button in the consuming file doesnt show eg the updated font colour.
Now our freelancer who uses a mac has also started experiencing caching issues in the working files. We regularly delete cache. But changes do not show. Its starting to get a real problem  😭😭😭😭
Hi ​@KatK ,
I understand that updates published from your libraries are not reflecting in your working files.
To cover the basics first, please confirm whether you are accepting the library updates in your working files after publishing changes. The Libraries icon should display a blue badge when updates are available.
If you've already accepted the updates but the changes are still not reflecting, you might want to try the repair tool:
  1. Open the file where the instance doesn't look as expected
  2. Select the instance → Open "Actions" in the toolbar → Select "Repair component connections"
  3. Refresh the file and try adding a new instance
If the issue persists after trying the above, I'd recommend submitting a bug report so our team can investigate further. Here's how:
Go to the Support Hub → Type "Report a bug" → Click "Start a chat"
Please include the following:
  • Direct URLs of the files where the instance doesn't look as expected, and the library the component is from
  • Share view access to the affected files with support-share@figma.com (our official Support account — you won't be billed for this access)
  • Any screenshots or video recordings of the issue
  • Troubleshooting steps you've already tried
With this information, our team will be able to take a closer look more efficiently.
Thanks!
KatK
KatKAuthor
hi! Many thanks for your reply! I didnt know about the repair tool so will definitely try this next time!
