Jan 17, 2024 2:15 PM UTC
Button | negative offset + auto-layout
Hey everyone,
current problem is the following:
I want to create a button with auto-layout and negative offset for the color-frame/rectangle below. The width of the button therefore needs to adapt to the content, but the main/parent frame is not allowed to be bigger than the stroke of the actual button (without color) for layout/design reasons (in combination with other components within a website/design).
Is there way this can work? I know I can create another frame w/o auto-layout so it has the same width as the frame with black stroke but this means the whole button won’t adapt to the content.
Bildschirmfoto 2024-01-17 um 15.10.13
Thanks in advance 🙂
Jan 17, 2024 2:17 PM UTC
To make it a bit clearer:
tank666
Jan 17, 2024 2:38 PM UTC
Just apply an absolute position to the background layer and give it left and right and top and bottom constraints.
Approximate component structure:
Button (auto layout frame)
    Content (auto layout frame with stroke)
        Text
    Background (an absolutely positioned rectangle with left and right and top and bottom constraints)
Ewald_Human
May 5, 2024 7:18 PM UTC
You my sir are a genius thank you very much 😁
