Byambasuren
Jan 12, 2023 2:51 AM UTC
Bug or what? Developers can't inspect spacing measurement between objects
In Jan 11 our developers were able to inspect spacing between objects, using command + mouse over in macOS. (spacing between 2 texts are 16pt etc…) But Jan 12 they no longer can do it unless I give them Editor permission. Is there anyone experiencing same issue? We tried cleared the all caches of browser figma etc…
rijoes.reoSolution
Jul 10, 2023 3:56 AM UTC
For those who think you encounter this same issue:
Try press alt(macos: option) while hovering/measureing between elements.
Figma changes measurement UX, you need to press alt to see measurements.
Serban_Vatavu
Jan 12, 2023 11:11 AM UTC
what worked for me:
  1. select first element
  2. press shift and double click on the second one.
    Hope this works on your side also
Konstantin_Kudinov
Jan 12, 2023 12:51 PM UTC
Just select one elemnt, then hover on second and zooming - padding appers
Gratessole_Oceane
Jan 12, 2023 1:01 PM UTC
Same issue as viewer !! HELP 😭
Robert_Ontiu
Jan 12, 2023 1:05 PM UTC
Step 1 → Adobe buys Figma.
Step 2 → Workflow breaking bugs start to occur
Josh
Former Community Manager
Jan 12, 2023 2:24 PM UTC
Hey all thanks for reporting this. A fix has been pushed and this should now be resolved. Let us know though if you’re still running into any issues.
Andrew70
Jan 12, 2023 4:57 PM UTC
The same problem. The side developer can no longer measure distances between objects.
Denis_Solyankov
Jan 12, 2023 4:58 PM UTC
I noticed that if you move the camera without removing the cursor from the object, the distance starts to show correctly.
Yawen_Tan
Please help us ! 😭
Ren_Natsume
me too. i had same issue.
parkjs6
appears to be the same issue. But even here there is no solution.
