Miti_Abulaiti
Jul 16, 2024 1:38 PM UTC
BUG (FIXED): I can't find corner radius in Figma Slides
Who else is trying to find where the corner radius is in Figma Slides?
The problem is sometimes it’s there, but sometimes not… 😰
djvSolution
Aug 27, 2024 3:40 PM UTC
Hey All, thanks for your patience and understanding!
The team confirmed that this bug was caused by conflicting coding logic that caused a different permutation of panels to compete with each other to be visible, affecting not only corner radius but also the layout grid panel.
Our team has developed a fix that will start being deployed later today through the end of the day tomorrow - stay tuned!
EmilyMoze
Jul 24, 2024 9:14 AM UTC
It is definitely a bug, I had to quit Figma and re-open it in order to see the corner-radius section. It was completely missing.
Jul 24, 2024 3:37 PM UTC
Hey All, thanks for flagging this!
We’ll pass this onto the Slides team to investigate. In the meantime, glad to hear that quitting/refreshing should fix temporarily.
EmilyMoze
Jul 25, 2024 10:12 AM UTC
Thanks for the swift response!
FYI I’m having the same bug with other functionalities too: for example, some minutes ago I couldn’t see the “layout grid” panel to adjust the guides, I tried switching back to Slides mode and then back again to Design mode to see the panel again. It also happened with the “Appearance” panel this morning, I couldn’t see it and regulate opacity, then closing and opening Figma again did the trick.
Jul 25, 2024 3:49 PM UTC
You’re welcome, @EmilyMoze!
Sorry to hear this is happening with other functionalities as well. I’ll pass this onto the team to try to repro and fix.
nanacodesign
Aug 13, 2024 5:11 AM UTC
I have the same issue 😦
I closed app and open again. But it didn’t work.
Aug 13, 2024 7:50 PM UTC
Thanks for chiming in, @nanacodesign!
I’ll pass along this feedback to the team that closing and re-opening Figma is no longer helping the issue.
Caio_Zafalon
Aug 26, 2024 12:11 AM UTC
Also cant find the corner radius. And reopen the app doesent change anything 😕 getting mad.
Aug 26, 2024 4:46 PM UTC
Sorry for the frustration, @Caio_Zafalon!
I’m following up with the team to hopefully get an update on their investigation.
Aug 27, 2024 3:03 AM UTC
Just had it happen to me as well.
Prazak_Dawid
Aug 27, 2024 6:07 AM UTC
Also had this happen with layout grid. It just disappears and randomly appears after 5 refreshes.
