Vanessa_Rychlinski
Aug 23, 2024 3:54 AM UTC
BUG (Fix launched & monitoring): Prototypes flickering black
It’s not happening in other prototypes. The screen will flicker black on and off even without any mouse or keyboard action
Aug 26, 2024 10:56 PM UTC
So happy to hear that, @Edgardo_Marcano!
Please do let us know if you run into any further issues.
Teeg
Aug 29, 2024 1:51 PM UTC
Still experiencing this too. Even after refreshing tabs.
I have troubleshooted some things and I think it’s actually related to my frames being portrait and rotated 90 degrees then viewed in landscape (because the option in Figma UI3 to choose landscape of a preset frame has disappeared so I had to rotate it by 90)
On frames that I’ve manually swapped around the width and height, and viewed in landscape, the flickering does not occur
Aug 29, 2024 5:47 PM UTC
Sorry to hear this is still happening for you, @Teeg!
Are you able to share your file with us, so we can take a closer look at what you’re describing? https://help.figma.com/hc/en-us/requests/new
If so, please use your Figma account email, include a link to the file, and share edit access with support-share@figma.com, so our technical quality team can take a closer look.
Teeg
Sep 6, 2024 9:19 PM UTC
Unfortunately not able to share the file with you (NDA) but I did resolve the bug by manually going and swapping all my frames width and height around so that it is a landscape phone screen but not rotated 90 degrees. Lots of extra labour and relaying out all the items contained within the frames but as suspected, this fixed the flashing. I’ve attached a GIF below to explain a bit better
ezgif-4-446ec26931
