Mojo
Oct 6, 2022 3:32 PM UTC
Bug Auto Layout and components overflowing containers
Anyone else having this bug, where things you paste, or randomly-based, overflow the container?
Every time y paste things auto layout seems to behave the worst way possible.
And as soon as you double click the component or break it, it gets fixed.
Se Video for reference pliz 🔗
zu.nguyen
Jan 3, 2024 10:34 AM UTC
2024 and still the bug
Mohamad_Ahmadi
Jan 15, 2024 12:26 PM UTC
Hey there
I noticed a similar problem on our project, when I tried to detect the root of the problem, I noticed that one of our teammates had done something wrong.
that was it: the whole auto layout was set to “Hug content” and on the other hand, the component inside of it were set to “Fill container”, so Figma couldn’t see the proper logic to calculate. To fix this, you just need to change of them.
generally Figma changes one of them, according to the last change to prevent this bug, but sometimes it goes wrong and runs to a bug.
I guess it will solve your problem too, and there will be no more jumpy-jumpy auto layouts or components or text layers 😉
cheers
Lucas_Rosendahl1
Dec 9, 2024 10:40 AM UTC
The bug is still very much there and I have had some minor problem the last year or so with this. However since the last month or two the bug has become so bad that it is everywhere right now and almost every component I update now gets affected by this.
Another problem with this bug is when I as a designer double click on it, it disappears and solves itself however the dev team still sees the original bug.
EDIT: after a lot of searching around here I found the following solution that seems to work for me by using the“Regenerate all instances (slow)” command from the Quick Actions panel. However this seems to only apply for a specific page and not the entire project so you will have to do it page by page.
